Results 1 to 16 of 16
Thread: vr 5l temp doin my head in
    01 VU SS UTE
    May 2005
    Moree
    Default vr 5l temp doin my head in
    hey all been a while since ive been on but now i have a question about my 5l.
    wen i bought it it had a v6 cluster in it n it ran about the line above a quater
    on the guage then would creep up to bout half then found out the clutch fan has
    packed it in. so any way we locked the clutch up so its direct driven to keep it
    cool till i get one next week and put the v8 cluster back in just coz its ment to
    be there. any now with the v8 cluster back in it sits on half or just over
    and doesnt move even on the highway at speed so we then replace the thermostat n
    no different. could this be the cluster playing up or the fan issue/
    theres no leaks any where n also the tacho sits at 200rpm
    at idle which makes me think the cluster. any help would be appreciated
    sorry but the story but im tryin to write this on an iphone lol
    thanks again...
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    200rpm at idle??? it should be sitting around 750-1000rpm at idle probs the cluster
    01 VU SS UTE
    May 2005
    Moree
    01 VU SS UTE
    May 2005
    Moree
    01 VU SS UTE
    May 2005
    Moree
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    the main diffrerence would be the V8 tach. every thing else should be the same as the V6.
    I've got a V6 cluster in my VS Calais atm. I'm needing to change the tach or the whole cluster depends whats available here in wa
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by BottleFedVS View Post
    i might have a v8 tach here sumwhere
    01 VU SS UTE
    May 2005
    Moree
    i cant work out y im gettin two different readings between the 2 clusters
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    By the sounds of it, you have 2 shagged/incorrect clusters. I would shout yourself a new one off ebay. They are fairly cheap. I have played with clusters before. I have 2 half ones here and a vn/p one from the l3 conversion i did. They are finiky things.
    Reaper
    01 VU SS UTE
    May 2005
    Moree
    yea i mite have to. wot is the sensor underneath the throttle
    body that has the single green wire coz i found it not hooked up?????
    VrWagz1's Avatar
    May 2008
    wollongong
    lol, thats the dash temp sensor. maybe just the problem
    The multiwire one on the manifold is for the ecu
    Reaper
    01 VU SS UTE
    May 2005
    Moree
    VrWagz1's Avatar
    May 2008
    wollongong
    shouldnt no. Its just a heat variable resistor that earths out the gauge slowly as the motor gets hot, giving you the needle rise. If its totally open cct, the needle should never get off the ground. If it was dead short then the gauge should be off scale.
    Reaper
    01 VU SS UTE
    May 2005
    Moree
    the guage dont move wen it gets to a certain temp not even
    at speed on the highwayy would this still indicate the cluster issue
  15. #15
    VrWagz1's Avatar
    May 2008
    wollongong
    Thats a strage scenario you have really. Cause it shouldnt operate at all if that wire is dosconnected. Maybe that wire you had was not the temp sensor wire. Have search on here or google for some picrures of where the sensors are located. If its the temp dash gauge sender unit, it will be on the base of the inlet manifold(under the throttlebody) next to the ecu temp sensor (so theres 2 sensors there beside each other).
    If the cluster is still working(albeit badly) then theres definatly a wiring or cluster issue there.
    Reaper
  16. #16
    01 VU SS UTE
    May 2005
    Moree
    ok yea im thinking cluster hopefully
  1. doin my head in
    By juzdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2010, 05:55 PM
  2. What i am doin (soon)
    By gareth89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2009, 04:50 PM
  3. Hey, how you doin?
    By kluckmeister in forum General
    Last Post: 13-01-2007, 11:38 AM
  4. Blue n Red doin in my head
    By adept in forum Electrical Wiring / Questions
    Last Post: 02-09-2005, 09:13 PM
  5. Doin up a Vt
    By de'laney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 12:31 AM
