so the only time i touched the engine was to change it to a pod filter did it all right had it running for 5 mines then it cut out so and wouldnt start againg so i put the box back on and it doesnt even fire now =/ help please?
so your saying that it cranks but will not start??
first of all do a diagnostics check. this saves alot of time.
Were any hoses or sensors unplugged to fit the pod filter, you may have forgotten to reconnect something.
i too was thinkin the airflow meter
some conections were unpluged but iv put them it but the crank wont even turn now
is your battery flat?
nah the radio still works, would a jump help it?
yes. battery prob hasnt got enough juice to turn the engine anymore
could be your battery in ur key thats flat
Powering up a radio is a world away from the power needed to wind over the engine via the starter motor.Try turning the headlights to high beam and then try the starter,do the lights go dim or completely off whilst trying to crank the engine? If they do,the battery is most likely buggered.If they stay bright,theres a bad connection somewhere between battery and starter or the engine earth side..
