Results 1 to 7 of 7
Thread: 1999 VS V6 Statesman Series III Fuel Tank
    VS V6 Statesman S3
    Jan 2011
    Gold Coast, Queensland
    Default 1999 VS V6 Statesman Series III Fuel Tank
    Hey Guys,
    Just wondering if the series 3 statesmans had the long rank tank 75lt as standard and is there anyway to tell what size it is from looking at the car without having to take it off.
    Any suggestions would help.
    Thanks
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    i think the long range tanks were 90L, if you post a pic of it someone will be able to tell you, it's fairly obvious they hang down loads more than the standard tanks..
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Holden VS service manual CD says:
    Fuel tanks for VS Series Models carry over from VR Series II models with the introduction of quick connectors at the fuel rail to fuel tank lines.
    On Statesman and Caprice models, the standard fuel tank is 75 litres capacity.
    On sedan models other than Statesman and Caprice, with V6 engine the standard fuel tank is 63 litres capacity. V8 sedan models have a 75 litre fuel tank as standard.
    Utility models have a 64 litre fuel tank mounted below the front tonneau floor. Removable covers behind the front right hand seat allow access to the fuel feed and return unions at the tank, the level gauge and the electrical connectors of the in tank mounted pump.
    Station Wagons have a 68 litre capacity fuel tank for V6 and V8 engines.
    An optional 75 litre capacity long range fuel tank is available only for sedans.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by nathanVS View Post
    close lol
    i only know that because i have clusters here so i looked at the switch on the back
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    Vn 5L were 90L I believe.
  1. V6 Supercharged Statesman WH 1999
    By robberds in forum General
    Last Post: 12-12-2010, 07:37 AM
  2. VS Series III 1999 Ute
    By jokerflingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2008, 11:30 AM
  3. 1997 Series II VS Calais Fuel Tank
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2008, 05:19 PM
  4. WTB: VS Statesman Fuel Tank
    By pimpplato in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2007, 11:31 AM
  5. Ecu Location Vt Series Ii 1999
    By badly_drawn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2006, 01:30 AM
