Im purchasing a VS S2 185i Senator in the next few days.
Im interested in transferring my Stroker engine from my VS S2 Clubsport and also my gearbox and diff
Both cars are autos
Will the engine gearbox and diff be a straight swap using the loom that exists in the senator
Also will i be able to simpy unplug and remove the senator computer and then plug in my computer as it holds the tune for my stroker motor?
My Senator 355 Stroker
http://forums.justcommodores.com.au/...5-stroker.html
Motor/box def fine. Diff im unsure. You will need to see if its IRS or live on each car. ECU def easy swap, but it will be 10x easier tyo just swap the memcal over(as above said)
16176424 for auto upto S2, so straight swap as above. S3 auto/man is 16234531 and S1 & 2 manual is 16183082 or 16206305 same as VR manual.
