Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Weird brake problem
    vs commodore
    Oct 2009
    Tamworth NSW
    Default Weird brake problem
    Yesterday I replaced the front and back brake pads,I removed the calipers to clean up and grease the slide pins, and to generally make sure the caliper seals etc were all ok...I completely drained the old brake fluid and bled the system.The pedal feel was nice and firm like it should be,I drove the car to bed the new pads in,and they bedded in perfectly...Then last night whilst driving into town,the brake fail dashligh came on, and the brake pedal was just about going to the floor when the pedal was pressed.I thought I must have left a bleeder screw a bit loose and she'd sucked in a bit of air,so I thought Id just check them and rebleed it this morning.Now this morning the brakes are back to normal again,they are exactly like they should be with new pads and a bled system.I checked the bleeder screws and brake hose connections, everything is sealed tight and not leaking at all.Ive never seen this happen before in all the years Ive been doing my own brake services.Has anyone ever had this happen, or heard of it happening, or maybe have an idea of what might have caused it.Ive since driven all over town this morning and they are working excellent again.
    Its a VS with no ABS.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Sounds like it had 1 small amount of air left in the lines. The second bleed did the trick hey.
    and 3 Dangerous non ABS VN's
    vs commodore
    Oct 2009
    Tamworth NSW
    I didnt end up re bleeding them this morning though,because they are back to normal again,the pedal is firm with normal travel like it should be,and it was just as firm first up yesterday when I bedded the pads in,this is what I cant work out,the brakes were excellent first up yesterday,then last night they went to the floor and the brake fail light was on,then this morning they are back to normal again with no light showing..
    88GreenVN's Avatar
    Jun 2006
    Strange indeed. Even if the booster fails you still have a firm pedal. The only way the pedal can go to the floor is if there is air in the line some place.
    vs commodore
    Oct 2009
    Tamworth NSW
    Strange alright,I cant work out what could have caused it. Theres definitely no air in the system as the pedal is heaps firm like it should be and has the proper travel,the booster is working fine,when the brake pedal is held in and the engine is started,the pedal sinks in a bit like it should..Its got me stuffed why its happened.And I dont feel safe driving it knowing that it went to the floor just out of the blue, but now is back to "normal" again.Ive found from past experiences that if a bit of air is still in the system,it usually just makes the pedal a bit spongy with a bit longer travel,but last night it was nearly to the floor.
    immortality's Avatar
    immortality is online now crappy ol' VN driver
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    possibly a master cylinder that is on it's way out.
    was there a lot of pedal travel with the old pads or generally more travel then you have now?
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah,there was a bit more travel there before I replaced the pads and fluid,but there usually is,the pedal always seems to get a little bit longer when the pads are near the end of their life.The travel was not excessive though,but you could tell the difference between how they were before and after the pad change,less travel and a good firm pedal.It "feels" just like it always has when Ive put new pads and fluid in,theres no difference there from any other time ive done it..I agree,I think its something up with the master cylinder.Theres nothing else that I can see,that would cause the pedal to just go to the floor just out of the blue and cause the brake fail light to come on.Ive been checking out the VT front brake conversion anyway,the VS is way underbraked at the best of times for a car that size and weight so I might kill 2 birds with 1 stone.Thanks for your time and input guys.cheers.
    88GreenVN's Avatar
    Jun 2006
    The VT M/C booster upgrade is very much worth the effort. All 3 of my VN's have now had this upgrade and I'm very happy with the brakes on all 3. None had the calipers or rotos changed so still stock in that area. I figure we are not racing anyone so if we have to stop big time once we can give the brakes a while to cool while we change undies so no need for 1,000 worth of rotors/calipers.
    Apr 2006
    Auckland NZ
    so whats happened most likely is that where the pistons was in the master cylinder it has worn into the alloy a little with the old pads, when you fitted the new pads the piston has moved back some in the master cylinder pack past the wear point. there may be a small ridge/lip in the master cylinder where it has let fluid past the piston allowing it to travel a lot further.
    the VT style MC is a straight bolt on (to your existing booster) but you need a small spacer to go between the MC and booster to get the spacing correct. or you could adjust the rod as it has a threaded section on the end but i'm not sure what length it would need to be adjusted to
    Apr 2006
    Auckland NZ
    Quote Originally Posted by 88GreenVN View Post
    i'll 2nd that. makes a huge difference to the brakes.
    VP Exec
    Jun 2005
    It does sound like the M/C.
    Quote Originally Posted by immortality View Post
    Sort of but the M/C pistons don't move during pad replacement, only the wheel cylinders do. What can happen is one of the M/C pistons moves further down the M/C bore during the process of bleeding and scratches the seal(s). It's also possible a lump of debris (product of corrosion) has been caught between a seal and the M/C bore. That might dislodge as the M/C piston returns and the load comes off the seal if the pedal is pumped.
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Cheap6 View Post
    yes and no. yes, when you fit new pads you push the pistons back into the calipers. you will also note that you have less pedal travel when applying the brakes with new pads so the piston in the MC is moving/working in a different spot then when you have old pads and generally have more pedal travel. either way a new MC would be good insurance.
    i do agree though, when the MC has only moved in a certain range for years it tends to wear in a such, when bleeding brakes and pushing the pedal right down can lead to problems.
    i have heard someone suggest that you could put a piece of wood under the pedal to prevent max travel to try and eliminate this hazard.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Agree with immortality an cheap6, Definatly sounds like the master was bypassing and the piston was travelling further down the bore where it possibly sealed again. Makes perfect sensce considering the brake fail switch is at the end of the master bore. Any brake failure like this should be treated seriously which i see you are. I wouldnt drive the car until you find a reason why that happened. You dont want that happening again at the wrong time.
    If ur interested in doing the vt master upgrade, i would suggest considering doing the booster too, due to the vt unit being more powerful then the vs booster.
    Reaper
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Is it possible that when the pads were installed and the calipers bolted up, one of the pads was 'cocked' and not sitting flat against the face of the piston....this may have prevented the caliper piston from forcing the pad square against the disc. You would have a solid pedal and if it was a rear pad you may not have noticed the difference in braking (with one pad u/s). after being left overnight/expansion/contraction/murphy somehow loosed the pad which then allowed the caliper piston to seat the pad correctly (and require more pedal travel for one push). Long shot eh!
    But I'd certainly be a bit worried.....but I'd agree with most posters that the MC seems a good point to start at...they are cheap enough new.
    Edit...about $220 on Ebay
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Thanks heaps to everyone for the replies and suggestions.Im gonna either replace the M/C for now with a new VS one. Or do you blokes reckon it might be worth just fitting a rebuild kit in the old M/C ?.I will be doing the VT conversion later though still,Ive made up my mind that I will spend the cash to do it because,for one, everone recommends it,and two, Ive always felt these cars are way underbraked,Ive owned cars with rear drum brakes that stopped better!!.So Ive just done the brakes,fitted a brand new set of injectors and finally got rid of the last of the rubber bushes,Ive now got full nolothane bushes throughout the car.The ones that were replaced were the front lower inner control arm bushes.Its thrown the wheel alignment out a bit,shes squealing through roundabouts and tight turns,a bit too much toe in by the look of it,but it still feels a lot better,excellent road feel,shes booked in tomorrow for an alignment so I will be able to then truly see what shes like.Ive also fitted a new genuine holden CAS,so its cost me $140 for pads,$180 with postage for brand new "cheapie" injectors off ebay,$120 for the CAS,and $50 for the bushes and $55 for the alignment tomorrow,not too bad I think.And free installation is always the best part,me and my two young blokes did it all over saturday arvo and sunday morning..The cheapie injectors are well worth the $170 I think,it starts quicker and idles and runs heaps smoother,I guess time will tell how they go though,and whether they will last for a good while or not.New bosch injectors were around $400 a set,and I really didnt want to go reco/rebuilt either,they want $99 on ebay for cleaned reco/rebuilt bosch injectors,the EFI places around here wanted $150 to clean and rebuild the old ones...
  16. #16
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    When you bled the brakes, did you push the pedal to the floor?
    Check the brake switch on the MC, undo it and wait for a click in the MC, that will reset the piston back to where it should be. If that were the problem it shows up as the brake light being constantly on, but it won't hurt to check.
    Visit my Facebook page
  17. #17
    VX SS
    Jun 2005
    So normally, most people upgrade to the VT MC and booster along with the twin spot calipers and discs. If you are just upgrading the booster and master, what is the benefit of this? Just a firmer pedal due to being a dual diaphragm booster on the VT setup?
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    The pedal didnt quite go all the way to the floor whilst doing the bleeding as I did the rear system first, then the fronts last,so they were both never undone at the same time, there was always some pressure at the pedal when it was pushed in.But what the you guys have said about what might have happened,I agree with,the piston has gone past its usual travel area in the M/C and its caused the seals to become temporarily displaced and theyve leaked fluid past them.Then the seal has somehow reseated properly after sitting overnight and resealed itself again.Im gonna look into getting a rebuild kit for the M/C tomorrow.When I first got the car,it looked like the fluid was all slimey and mouldy,Ive never seen anything like it,but when I cleaned it all out,and changed the fluid,it was working fine,so I have never replaced it.I probably should have.Well its gonna be done now.
    yeah,I tripple checked the pads again after the systems were bled,and they all looked to be sitting fine and in the right places.None were sitting crooked..Ive had that happen before and I always recheck them after the bleeding now.
  19. #19
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Brett, if you're playing with the MC and will in the near future upgrade to VT brakes, why not throw a new VT MC in now....brand spanking new they are $210 + post on Ebay. Might also need the booster ???
  20. #20
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by hako View Post
    Yeah,I have been reading up about the conversion, trying to get as much info as possible first,and Ive just read that if you use VE calipers instead of VT to VZ calipers,you can just use the normal VS booster and M/C instead of having to change the lot over.Apparently the VE calipers have smaller pistons than the VT to VZ type,so you dont end up with the long pedal problem..It would be way better not to have to make spacers etc for the M/C,that sounds like a lot of mucking about.And I definitely dont want to end up with a long brake pedal.It this right about the VE calipers not needing the different M/C and booster?I havent read it anywhere else,so I wasnt 100% sure about it,but thats definitely the way I will go if it is right.
  21. #21
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I'll say a M/C fault too. When it faults you could test it by clamping the three brake hoses.If the pedal is still crap, its the master.
    If I was to do my brake conversion again, I'd go for the VE setup. Smaller pistons will save a world of pain.
  22. #22
    VrWagz1's Avatar
    May 2008
    wollongong
    VE calipers need an adaptor plate dont they?? But i really didnt have to much trouble with my vt brake setup. Calipers were a snap to fit, and the vt booster n master slipped in with minimal fuss. Im sure if i was doin it for the first time again and had the step by step instructions i did here for it, then i would save a whole lot more time again.
    From scratch you would have a full days work ahead of you, but since i cheated and bought the booster/master with modified bracket ready to go off another forum member here that builds them, i saved a bit of cutting and welding time.
    If it is true that ve calipers suit the 15/16 master then i would just do that on vn-r because the booster is around 4x anyway compared to the plastic single diaphram Vs 3x booster. The vt is only around 4.5X
    Reaper
  23. #23
    vs commodore
    Oct 2009
    Tamworth NSW
    Thanks heaps fellas, I appreciate hearing everyones thoughts and experiences on the subject.Does anyone know for sure, 100%, that the VE calipers will work properly with the normal VS master cylinder and booster?And will the calipers bolt straight up to a VS.And thanks again everyone.
  24. #24
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes they work, I have supplied a number of these setups and they bolt straight on. The kit comes with all hardware: brackets, bolts, lines, everything you need to fit it to the vehicle.
    They work fine with the stock M/C as the pistons are smaller than the VT's, so they displace less fluid keeping the pedal feel the same.
    ( I do the slotted kit for $795)
  25. #25
    VrWagz1's Avatar
    May 2008
    wollongong
    NotanAbbaFan??spelling would know for sure if u pm him, i think he retails the stuff or somthing. I am half certain an adaptor is needed to fit the calipers on, whereas vt calipers bolt straight on. Both obviously need the correct rotors installed also.
    Reaper
  1. VT weird problem, please help
    By JSTCOZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2010, 12:45 PM
  2. weird vn brake lights???
    By vn_bt1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2009, 08:12 PM
  3. Weird Brake lights
    By VRnz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2007, 10:17 PM
  4. VS weird Air con problem
    By -Davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 10:26 PM
  5. my weird problem...
    By raZel in forum Car Audio
    Last Post: 10-02-2006, 11:53 PM
