Hey all,
Just wondering if these will fit on my ute? it has been lowered an inch in the rear.
I do plan on carrying 2 x 250CC Motorbikes , What size tyre profile should i go? what width tyre should i go? will it scrub out bad with the motorbikes loaded in the tray?
http://forums.justcommodores.com.au/...s-100_3345.jpg << fitted on the ss sed....as for scrubbing(heavy duty shocks should help out some there) if you springs aint to low already
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
thanks all i dont know what the offset is but if it helps heres a pic of the wheels im getting.
Hey mate, just thought I'd let you know. on my Vs ute I am running 19" rims with 245/35's and don't have a problem. On the front it was slightly against the strut but just screwed the camber out a bit and now it's clear. Under the back is Close (my ute's almost on the bump stops) but it all fits and even with a load in the back doesn't change a thing! Hope this helped!
thanks very much guys , they fit perfect appreciate it, will post pics of them on my ute tommoro
here it is.....
