Just installed a new washer pump into my vr. Problem is now that the water shoots miles too high and just lands on the roof barely hitting the screen.
Any ideas on how to aim these better?
Are the water exit holes on the bonnet? They might need to also be replaced as they would be warn,try and just get a safety pin and stick it in the holes where the water comes out and move it around and see if the water hits the wind screen
id go with what zelby said i just pulled mine out the other day to paint them and they only go back in one way so u wuldnt be able to adjust the angle of them at all realy. hope it helps
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
I aim them by puting a needle into the nozel and move it to where i want it to aim. So far no one has mentioned how to aim them just how to clean them?
The Daily VN T5V6
355 VN GRP A REP
yep - that's what I do too. Sometimes a bit of "gunk" builds up and you need to ensure that you do not push it down into the hose.
Cheers all used the pin trick and aimed them down works a charm.
Im sure that zelby11 mentioned that you move the pin around until the aim of the water is on the windscreen
