Results 1 to 13 of 13
Thread: Oil or not
    VS Commodore Excutive
    Sep 2010
    Cool Oil or not
    First thing in morning start my VS ecotech V6 up and get a noise like tappets or something last only about 15 seconds, the car has done 260,000 and goes great and im using NULON 15-40 OIL so is the iol or what thanks.
    VR Berlina
    Jun 2010
    VIC
    i always thought it was normal for the 1st few seconds. my car did that for a few minutes so i used nulon lifter free and it fixed it right up. only makes noise for about 5-10 seconds now. maybe give that a go
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Should be using 20w-50.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Mar 2008
    ive been using 20-50 and get a bit of a rattle at start up
    was thinking of switching to 10-50 for better flow at start up
    vs commodore
    Oct 2009
    Tamworth NSW
    I use penrite HPR15 which is a semi synthetic 15W-60 oil,Its a bit thinner at cold startup for better flow,but also stays a bit thicker at high temps for better protection in our hot aussie summers....
    Sep 2010
    Quote Originally Posted by Brett_jjj View Post
    thanks for all the info people
    Mar 2008
    i saw that on their site as well
    think i might grab some on the weekend and give it a try
    cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive used it for a couple of years now,and its good oil..And its not too expensive.Id really like to use a full synthetic oil like mobil 1,but its just too expensive for me to buy regularly..I change my oil and filter every 5000 k's.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    change brand of filter ryco's and another brand the anti drain back valves have issues and cause rattle on startup due to the filter emptying overnight
    Mar 2008
    VX SS
    Jun 2005
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I have had good results with HPR15. Used Valvoline Durablend 15w40 semi synthetic for as long as i can remember in my cammed v6. Thought i'd try HPR15 as the lifters would get a bit noisey after a thrashing. Now i wouldnt go back to valvoline
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VR Berlina
    Jun 2010
    VIC
    Quote Originally Posted by RUF 231 View Post
    thats interesting i actually did that the opposite way around to what you did. i didnt notice any difference though so i stuck with valvoline as i can get it cheaper. maybe v8's are different
