Results 1 to 3 of 3
Thread: Air COn pulley bearings
    VSII Acclaim Wagon
    Feb 2011
    Default Air COn pulley bearings
    Hi, It seems that my bearings are gone on my a/c compressor pulley as it is making a terrifying noise and spitting sparks.
    Can I replace the bearings?
    If so, do I need a special tool to remove/replace the pulley? Armature spanner I imagine. Anything else?
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it's spitting spark it sounds more like the magnetic clutch is slipping - it is metal to metal and if it slips you may see sparks. It may not be the bearings but the fix may be just as expensive as the front of the comp needs to come off.
    Here is a link to the compressor service manual - read it and you'll have an idea of what's involved. Sanden USA: Service Manual
  1. Noisy V6 idler pulley or air con bearings?
    By fragmoider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2011, 03:24 PM
  2. Help on replacing air con pulley (bearings?)
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2010, 11:31 PM
  3. VS Wheel Bearings & Axle Bearings
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 07:41 PM
  4. replacing bearings on Drive Belt tensioner Pulley
    By turkeychicken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:23 PM
  5. pulley bearings
    By Stretchomatic in forum V6 Development And Modification
    Last Post: 05-01-2006, 11:21 PM
