g`day guys i need some help , my wifes vs is hard to start when the engine is cold. starts fine when engine has warmed up. have done a fault code check, full cycle of code 12, engine runs good when started . battery is fine 1 year old , alternator puts out 14.2 volts engine running , new leads and spark plugs 6 months ago. have cleaned throttlebody and airflow meter, last year CAS was replaced. last week i removed coils and checked resistance with multimeter, readings within specs . could it be clogged fuel filter?. will be gratefull for any ideas , thanks
Very well could be just a clogged Fuel filter, cheap and easy as to replace and if it hasn't been changed for a while then that would be the first thing I would be changing. If its still doing that i would be looking at maybe your Starter Motor is on its way out, The prongs that the solenoid slides along could be getting worn making it hard to create a spark. If your going to change it, make sure you depressurize your fuel lines first.
If it's not a Symptom its not relevant, and if its not relevant I don't care!
No worries mate, if you need a hand with anything let me know, I'm basically on the Central Coast as well. What part of the Central Coast are you on?
Awesome man, like I said man ever need a hand I'm only 15mins away. Let us know how the Fuel Filter goes.
Injectors themselves could also be to blame. Though they aren't cheap to have a workshop check them out. Could be worth looking at if the fuel filter change doesn't bring any improvements.
my vs v6 in my vn done the same thing it ended up being the tps
tuning done by THE1 A+++++ tuner
And powering it by MACE
Build it to handle the MANG
thanks people for your replies , i will replace fuel filter and see if that helps . if that doesnt fix it will try TPS and coolant temp sensor.
I have the exact same problem.
It isn't the coolant temp sender or the fuel filter. Trust me.
Possibly injectors?
Try the TPS and let us know how you go.
today i put a new fuel filter on , and also replaced the TPS and the coolant temp sensor .[ GMH f*****g xpensive ] . and i took the vacumn hose off the fuel pressure regulator no petrol came out so thats ok. i wont know how it is till 2morrow , when i can do a cold start.
did a cold start this morning , still the same really , took about 15 seconds of cranking b4 it started, anyone got any more ideas? the car has a Greenfoam memcal in it and uses 95 premium unleaded fuel . should i try some injector cleaner , or should i put the standard memcal back in ?
does the fuel pump prime before starting the car
