Results 1 to 7 of 7
Thread: weak alarm
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    Default weak alarm
    on my VS the car alarm just doesn't sound as load as it should, i set of the one on me mum magna, and it nearly blew my ears off, but on the commodore it was just faint, not as load as it should be.
    i've checked all connections and the horn it self works well, but i have no idea what the hell is making it so weak? is it mean to be like that?
    cheers.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    As far as I know the alarm does not use the same horn as the normsl one... Last I knew it was located closer to the passanger side window?
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Quote Originally Posted by James39 View Post
    correct, its under the bonnet, passenger side between firewall and strut tower basically
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    not all, i thought it was the luxo models.
    set it off by winding down passenger side window, lock the car with the button on the key, then pull up the passenger door lock and open the door
    elmaso's Avatar
    VR Calais
    Jul 2010
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    All VS Commodore alarms are aftermarket and only rarely fitted as an option from new....standard they came with an immobiliser but no alarm so if you were not told about it when you bought the car you can bet your bottom dollar you don't have one.
  1. is my handbreak weak?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2010, 02:00 PM
  2. How weak is weak
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 10:56 PM
  3. Weak brakes!!
    By keza87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 10:01 PM
  4. Weak Headlights
    By craige1982 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 11:29 PM
  5. Weak VB!
    By kman31 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2005, 05:42 AM
