Hi, can anyone tell me if the VS 2000 Series III Olympic Commodore Ute has 1 or 2 horns. I've bought one and noticed on the opposite side from the horn, there's a wire that has nothing connected to it. Maybe it's meant for a horn. Be great if someone could let me know.
Some of the higher level cars had 2 horns fitted,one is a higher note,the other is a lower note.My VS exec only has the 1 horn fitted.
correct, actually you can clip in another horn off those wires and it will work... most guys grab the statesman high and low hows and whack them in![]()
why would anybody ever need 2 different horns??
Thanks for the info guys. Not sure which way to go.
Or if you really want... run a air horn of it via a relay
