Results 1 to 4 of 4
Thread: VS V6 Electrical Issue
    VL
    Jan 2011
    Default VS V6 Electrical Issue
    Hi
    I just put a new engine & gearbox into my vs v6 and I am having some problems I hope someone can help me with.
    Basically the engine light is staying on constantly under 2000rpm. Any gear changes around here are a bit clunky but tight, they smooth out if I get the revs up.
    The engine light turns off any sort of consistant throttle over 2000rpm for even a second or two.
    I am thinking its electrical but I can't pinpoint it.. so far no fault codes that I can see.
    One other question is the little valve drivers side rear of the engine, has one hose going to the throttle body, one hose going to the charcol canister, but I cant figure out where the hose on its own goes.
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There must be something electrical that is not plugged in as the engine light MUST leave a fault code once it comes on. (have you removed the paper clip from the plug?) Check the connections to the ECU also TPS and VSS....also vacuum hoses to TB. Re hose - possibly it's the one that goes to the fuel pressure regulator. I wouldn't do too much driving till you locate the problem as harsh changes etc will kill the auto.
    Good Luck.
    VL
    Jan 2011
    Gday
    Cheers for the help.. turns out I didn't put the little plastic clip that actuated the tps, it goes between the throttle body and the tps my bad I guess hopefully helps someone else as it was pretty easy to forget.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's usually something very simple. Glad to help and great that all is OK.
  1. electrical issue
    By alomania70 in forum Electrical Wiring / Questions
    Last Post: 04-12-2010, 08:24 AM
  2. VT electrical issue
    By fenda in forum Electrical Wiring / Questions
    Last Post: 20-10-2010, 03:29 PM
  3. Issue With Electrical
    By mrvdv85 in forum Electrical Wiring / Questions
    Last Post: 17-09-2009, 10:50 AM
  4. Sos Electrical Issue
    By stuballs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2008, 10:31 AM
  5. VK electrical issue
    By kik in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 09:13 PM
