Results 1 to 6 of 6
Thread: wierd brake light problem
    1993 Vr Berlina
    Dec 2010
    NSW
    Default wierd brake light problem
    okay so everytime i put my foot on the brake i poop a fuse straight away
    now the bulbs are fine, light up with headlights on etc
    checked the lights and wires at the taillights everything looks fine
    what could cause this?
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the trailer wiring plug if theres one fitted.Sometimes these wires can be pulled half out of their sockets and they touch eachother,this would cause the fuse to blow each time the brake light comes on.A lot of the commodore genuine trailer wiring harnesses can be unplugged from the cars wiring in the boot on the drivers side,this is probably the easiest way to confirm if its faulty or not.
    1993 Vr Berlina
    Dec 2010
    NSW
    oh okay thanks for that
    yer it has a genuine tow harness on it
    also there was just one random blew wire hanging from it so i tapped it up
    but yer ill try your idea
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Jpm_031 View Post
    Mine also has the blue wire hanging down not connected to anything,and Ive seen others like it too.Id say its supposed to be like it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have you recently changed stoplight bulbs?....it is easy to fit the wrong type which will short the circuit.
    1993 Vr Berlina
    Dec 2010
    NSW
    no i havent touched them since i got it
    tryed the trailer plug thing, fuse still blew so not that
    so im going with brake switch
  1. brake light problem
    By vtfan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2010, 10:28 AM
  2. Brake light problem
    By sathiya78 in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-04-2010, 10:31 PM
  3. Brake Light Problem
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2008, 08:38 PM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  5. VS brake light problem
    By 86VL5spd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 10:10 PM
