Results 1 to 2 of 2
Thread: Vs v6 issue need help plzz
    VB & VL
    May 2010
    Default Vs v6 issue need help plzz
    Hey all i have a 95 vs v6 that one day driving along the highway randomly lost most of its power and the car wouldnt let me rev over 1500 - 2000 rmp and is a slug now... soo got told the ecu was is limp home mode so seeing as the car had 300 000 kms i decided to replace the motor and gearbox all together after replacing the motor,gearbox,wiring loom and ecu the car still has exactly the same problem????? the new motor was out of a v6 bt1 so new runnig gear and still same problem...
    any suggestions to what it could be???
    cheersss fellas
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the problem was a collapsed catalytic converter....it blocks the exhaust gases and you will be restricted in revs/power....yours is a classical symptom.
  1. Vz wont start Starter motor? plzz helppp
    By vz23kq in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 07:13 AM
  2. VR commodore firewall problems plzz help!
    By VR_Berly in forum Car Audio
    Last Post: 24-12-2008, 06:22 PM
  3. problem, im lost, plzz help
    By danny_sway in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-03-2006, 01:31 AM
  4. Some INFO plzz
    By chris_1987_VL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2005, 11:37 PM
  5. PLZZ HELP... how much will this cost
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2005, 09:22 PM
