Results 1 to 5 of 5
Thread: Clutch cable very stiff, how to fix?
    TOW PIG
    Nov 2009
    New Plymouth NZ
    Default Clutch cable very stiff, how to fix?
    Hey all,
    I knew the clutch cable in my VR ute was very stiff ie: hard to depress, but i didn't realise how hard it was until the other day when i was moving my cars around.
    I moved my VN and then jumped into the VR and shit what a difference lol, the clutch in the VN is so smooth and easy to depress.
    Does the cable need lubricating or...........?
    cheeRS.
    Apr 2007
    I was thinking the same thing bout mine ute the other day.. I hav a heavy duty clutch but didn't think that would be the reason why it so stiff
    VS UTE SS Manuel 304, Excedy HD, Trutrac 3.45, 155rwkws
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    They arnt real dear. Just by a new one and replace it. More then likely the cable has worn a grove in the anaconda and is sticking in it. You'll also spend less time just changing it then you will trying to fix the old one. win-win
    Reaper
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also have a look where the cable goes thru the bulkhead - the metal can flex and crack causing the cable to work at an angle making it very stiff.
    VY Calais
    Oct 2009
    Quote Originally Posted by hako View Post
    Thats what was wrong with mine so start there
  1. clutch cable
    By Braydenreid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2010, 12:35 PM
  2. clutch cable
    By vs hay hauler in forum Holden Commodore Part Numbers and Descriptions
    Last Post: 25-02-2010, 02:35 AM
  3. vs clutch cable
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 07:15 PM
  4. [WA] WTB: VN-VS T5 clutch cable
    By Chirpstr in forum Swap / Wanted to Buy / Trade
    Last Post: 07-03-2009, 09:04 PM
  5. cable clutch
    By not_just_any_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2005, 12:41 PM
