Any1 know how to fix a slipping gearbox?
The gearbox can't slip unless the teeth are stripped off the input shaft or the gears. I would say your clutch is slipping, replace it.
Unless it is an auto, if so, then the bands or the clutch packs are worn, it may need overhauling.
thanks for the reply mine is an auto
