Results 1 to 7 of 7
Thread: bleeding vs v6 clutch
    97 vs ute
    Nov 2010
    Western Australia
    Default bleeding vs v6 clutch
    hi
    yesterday i attempted to bleed my clutch with my mate, went to spuercheap auto and bought a 'one-man' brake and clutch hose.
    fitted it to the little nozzle near gearbox as said my ellery's book, pumped the clutch hundreds of times yet no fluid.
    We tried to un-block the potentially blocked nozzle yet still nothing.
    help?
    thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd try removing the bleeder screw completely and clean it, then use a needle/pin/wire to unblock the hole the bleeder screws into. Don't use mineral oil on the bleeder screw....just a toothbrush and water. You could also try pumping the pedal with the bleeder removed.
    97 vs ute
    Nov 2010
    Western Australia
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Matts-97vs View Post
    and if neither of those work?
    Replace the slave cylinder....but first try to get the fluid flowing using the methods I suggested. (unless the old cylinder is leaking or otherwise damaged). I'm not sure what a new one costs, but cleaning the old one costs zero.
    97 vs ute
    Nov 2010
    Western Australia
    ill try my best
    thanks mate
    one more thing, i open the resevior cap and in the fluid is a black disk floating about 2cm diameter..
    wtf?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Im with Hako. Try removing and cleaning the bleeder nipple first or even gently pumping the clutch pedal with the nipple removed. If still nothing, then one of the seals in the slave cylinder is most likely stuffed. You can either put a new seal kit through the slave or replace it. I've not bought a getrag one before, but as a comparison I just put in a new slave cylinder into a vl and new from holden was about $65.
    As for the black disk, my guess is its the one thats supposed to be attached to the reservior cap on the underside.
    97 vs ute
    Nov 2010
    Western Australia
    cheers
    ill get right on that, along with my many other ute problems.
    its never ending!
  1. Bleeding the Clutch on a VY SS Manual Ute
    By MbCowboy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-08-2011, 04:13 PM
  2. Bleeding vx ss clutch line
    By Smashn2nd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2009, 01:45 AM
  3. LCD Bleeding
    By boobotam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2009, 09:02 AM
  4. Clutch Bleeding issues
    By the_duke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 10:53 PM
  5. bleeding ABS???
    By NVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 02:22 PM
