Results 1 to 9 of 9
Thread: Charcoal Canister
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Default Charcoal Canister
    Hey guys,
    I have a fuel smell in the cab of a vr ute and had a few questions about charcoal canisters.
    1: Is their a way to test them out to see if they are still good? I have three sitting here and am unsure which one to use.
    2: Any way to clean or flush them out? I realise I can buy a new one from zupps for $180 but thought i may as well check.
    Not sure where the fuel smell is coming from. I have replaced the breather line on top of the fuel tank, the breather under the charcoal canister as well as swapping the canister itself. The smell only appears on a full tank so I will have to check the top of the fuel tank as well as overflow lines. Next to check would be injectors?
    Cheers for the info guys
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I don't really think they ever wear out...the charcoal absorbs the fumes/airborne fuel vapours then they are removed by engine vacuum when the car starts....basically nothing to wear out except hoses to split.
    Rusty's Avatar
    Mar 2010
    Queensland
    Quote Originally Posted by hako View Post
    I thought that also but my mechanic said that it is compulsory to change every 150 xxx kilometers. He didn't change mine or anything but was just informing me. Thought it was odd and he could very well be wrong!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've never known anybody to replace one unless damaged but I'm sure some people do.
    VL Commodore
    Dec 2008
    There may be a one way valve on the Canister that can go bad which seems to be the only reason for replacement of the whole canister.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    I`ll have to do some searching.
    I`m sure I read they get blowen out with compressed air.
    Don`t quote me on that lol.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS_Pete_1's Avatar
    Dec 2007
    VR 5.0 ltr Ute
    Nov 2009
    Beenleigh, QLD
    Ahhh check you fuel filler cap, the ring in them goes bad sometimes too
    "I realize you were young and inexperienced at the time, but in hindsight you should have chosen your parents more wisely."
    Rusty's Avatar
    Mar 2010
    Queensland
    Quote Originally Posted by VS_Pete_1 View Post
    Cheers mate, that is what I was searching for! I have attached the info for others to reference.
  1. charcoal canister
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2009, 09:57 AM
  2. Can anybody tell me where the charcoal canister is on a vz ss ute?
    By nealie84 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-04-2008, 10:40 AM
  3. VT V6 Charcoal Canister Diagram.
    By Snowy7 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2008, 03:15 PM
  4. charcoal canister
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2007, 04:01 PM
