Results 1 to 7 of 7
Thread: VS rough idle
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Default VS rough idle
    G'day, so my VS shakes and vibrates a little in park, when in drive and stopped (at the lights etc) it will idle pretty rough, it will go as low as 400-500rpm. It's on dual fuel also.
    Any suggestions on what this could be?
    Series III CV8 & VS Acclaim
    Jan 2009
    In a House
    I had a similar problem with mine and it tumed out to be the spark plug leads.
    If you have a multi meter that does ohms it wouldnt hurt to check them. Cylinders 1,3 & 5 should have a resistance less than 10,000 ohms and 2,4&6 should be less than 17,000 ohms.
    Mine was running terrible at idle and this was all it was. It also wouldnt hurt to check your spark plugs while your at it.
    Shambos Ride! Check it out!
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    I agree with Shambo check the leads my number 2 lead went also and the same thing happened,and you cant adjust the idle on a vs because it is factory set.
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    i got the same problem and am hoping its just leads/plugs cause their easy and i know they need doing
    and it doesn't bog down like if a coil was dead/dying
    Vz SS 6LT
    Dec 2010
    melboure
    yeh my vs l67 was doing the same, change the leads and plugs hasent happen since, gotta luv when it a simple fix
    Jul 2009
    Bordertown SA
    Jan 2009
    In a House
    Quote Originally Posted by White Tiger View Post
    just changed leads and now its back to idling smooth
    so simple and so often over looked, nice one
  1. rough idle help
    By mitchvsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2012, 08:40 AM
  2. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  3. VX rough idle
    By Roh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-10-2006, 05:38 PM
  4. Rough Idle???????
    By m3taL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2006, 08:10 AM
  5. vr rough idle
    By hakhawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2005, 12:45 PM
