Results 1 to 7 of 7
Thread: Need help asap cleaned tb and sensors now ive only got 1st and 2nd
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Need help asap cleaned tb and sensors now ive only got 1st and 2nd
    Hey guys and gals as title says i pulled my throttle body and the sensors and at first it coughed and spluttered, Now it tries to die at first taking off but picks up and its only got 1st and 2nd,, first revs to 3000 before changing, goes into second and revs till 3 and wont go any further, and to get it to pick up speed u put foot down on the accelerator it will free rev till 2500 then tries to build speed any help please.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Vr acclaim
    Jun 2010
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You probably lost the plastic clip thingo that goes between the TPS and the TB....or forgot to reinstal it. You ain't the first!
    Vr acclaim
    Jun 2010
    is that the blue spring looking thing or sumin else if so i prob lost it anyone got a pic of it
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    hako is on to it. under the TPS (the flatter plastic sensor) there is a tiny plastic cap that goes on the tip of the tb shaft. that HAS to be in place of else the computer will get all confused and chuck a hissy fit.
    Pays to remember to put everything back exactly the way it came off
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Vr acclaim
    Jun 2010
    it must of come off then i didnt see it come off but when i tried to put it back on it clicked is that bad and are vs ones the same
  1. MAF. Anyone cleaned one before.
    By wassaby in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-05-2010, 11:27 PM
  2. New injectors vs reconditioned vs cleaned
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2006, 12:55 PM
  3. should you get your injectors cleaned
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 03:15 PM
