Results 1 to 4 of 4
Thread: vr v6 master cylinder steel hoses to abs module where tyo buy replacement hoses
    peter1 is offline peter1
    vr series 2
    May 2010
    Default vr v6 master cylinder steel hoses to abs module where tyo buy replacement hoses
    Does anyone know where you can buy replacement steels hoses from the master cylinder steel hoses to abs module.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Any wrecker should be able to supply them. New they would cost heaps. If you have the old ones you could go to Enzeds or similar and they will make one for you on the spot....but my first stop would be the wreckers.
    vr series 2
    May 2010
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Wreckers, or check ebay for wrecked commodores and ask for the parts there too, check the f/s section here for cars being wrecked out, may get them there too. Also put an add in the WTB section here too.
    WRECKING: VQ Statesman 5 litre.
    Have a look at the pics of the engine bay here, an see if they are the same looking.
    Theres also a vs wrecking in there too, but i think they are different. Remeber if the lines are close and have the same ends, they bend real easy to mate them up. They are a very soft pipe.
    Reaper
  1. [VR V6] replacing all radaitor hoses, power steering hoses, etc need help
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 08:40 PM
  2. master cylinder replacement
    By Cuthie in forum LSx Development and Modification
    Last Post: 05-03-2009, 11:11 AM
  3. VT II S: Clutch Master Cylinder replacement... and diff whine
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 07:53 PM
  4. VK - Replacement Brake Booster and Master Cylinder?
    By philbio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-02-2008, 02:08 PM
  5. vn master cylinder replacement
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2004, 08:15 AM
