Hi all got VS v6 Commodore had noist taps or lifters on start up then it went away so thought ill put the nulon lifter free in about 1 week ago and still in now and still got the noise but its there all the time whats can i do thanks.
Check the inlet manifold gasket hasnt got a leak
It could also be an exhaust leak.
check the manifold bolts . pretty common for them to snap in the heat
thanks to all but all fixed now i hope, gunk on oil pickup it was so was cleaned up and oil pressure good at 60 to now so all is fine thanks.
Yea no worries, after shovinf a bottle of nulon lifter free and driving aroung for a week with it in,i drained then stuck some new oil just for a couple of days i left it in then drained that out and it actually came out like ice coffee lol .
Then i borrowed a camera of a mechanic mate and jacked up the motor a bit loosened sump enough to get the camera in and checked it all out and i guess i was lucky as mine was all clean as a whistle so im hoping it stays that way now.
Hello with this noise you are getting is your lifter it makes a tapping noise and reason I know this because mine is doing the same so last night I took valley cover off to find one that is tapping I found bad lifter bit of info for you the vs commodore has roller lifters and when I took bad one out the roller on bottom broke a piece out of it I was lucky that it did not mark cam
