OK im new to the forum so first of hows it going it going i guess is in order
but secound of is I wanted to buy some VE standard rims and put them on my VS was just wondering if the stud pattern was different ( i vaguely remember someone telling em they are) so yea are they different
these are the rims im looking at getting if it helps http://www.toptentyres.com.au/store/...S%2018INCH.JPG
Hey i was thinking of doing the same thing... the stud pattern isn't different... however i have been told that the diameter on the wheel studs on the VS are slightly larger in diameter by a couple of mills; don't remember if its 1 or 2 mills its not much... but trying to re-bore the holes on the rims will be a b*tch... and your gonna hope that if they do re-bore the rims that they do a great job at it... =D
wheel nuts on vs are smaller, ve uses 14mm and vs uses 12mm...
ve hub size (center bore) is about a mm smaller then the VS hub size, its the center bore that needs to be machined out for them to fit. about $20-$25 per wheel.
you also need correct profile on the rims or else the tyre will hit the strut tower.
i put these same wheels on my vs ute about a month back, going great.
yea i got a private msg explaining this last night from soop ( thanks mate ) yeah and the widest tyres you can fit on them are 245 as they rub on inner strut >={ to easy to bore them out i got cnc's at work =)
My Vs " Liberator 1" =)
Side note : A V8 doesn't kill, the ######## driver who cant handle one does
LOL!
