Results 1 to 6 of 6
Thread: Np Spark
    VS Executive S2
    Oct 2010
    Central Victoria
    Default Np Spark
    3.8 Litre 1996 Model
    Yesterday while driving my Belt shreaded, i changed the belt over on the spot but ended up having to get my car towed, The shreeded belt has done damage to the hood lining and i was wondering if anyone knows what it could of knock/torn that does/helps spark the engine? Thanks in adcance.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Possibly the belt got caught behind the harmonic balancer and has damaged the Crank Ange Sensor, or it may have damaged the DFI module which is under the coils - look for rub marks and also check all connections in the general area.
    VS Executive S2
    Oct 2010
    Central Victoria
    Checked every connection i could see, Under the coils is where i thought most likely but it seems fairly well protected and undamaged, A lot of the belt ended up underneth the engine.
    Battery Is now dead will have to wait for 4 hours to continue trouble shooting, Feel free to give me trouble shooting tips
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by hako View Post
    I would do this.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    After you get the battery back in and give it a crank, check the error codes. Hopefully if it damaged the CAS it will flag it up in the codes for not seeing it.
    Reaper
    vs commodore
    Oct 2009
    Tamworth NSW
    If the CAS is damaged,it should spit error codes 46 and/or 47.Error code 46 is crank angle reference signal, (engine will not start when this code is set and active).Error code 47 is crank angle reference signal (no signal).
    Ive seen these belts come off before and damage the harmonic balancer,these balancers have interruptor blades at the rear of them,these blades pass through the CAS to generate the reference signals,and the blades can hit the CAS and damage it if the balancer is damaged at all .Its worth removing the belt and checking the balancer for movement,lever it back and forth with a screwdriver to check for any movement,also try to turn it back and forth and check for any play...
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  3. no spark
    By Matty o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2006, 08:01 AM
  4. No Spark
    By parkvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2005, 10:43 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
