Results 1 to 8 of 8
Thread: Opinions on the Pedders GSR front shocks for a VS ?
    VS V6 T5 & VY V6 M35 UTE
    Oct 2004
    Jurien Bay WA
    Default Opinions on the Pedders GSR front shocks for a VS ?
    I have recently fitted the Pedders Gas Sports Ryder struts with a set of lowered lovell springs to the front of my VS sedan. The rears have lovell springs with Pedders Comfort Gas shocks.
    I also fitted all new bushes / tie rod ends & ball joints along with 30mm front & 22mm rear blade adjustable sway bars.
    After a few weeks of checking & changing wheel alignment specs & bar settings, I have come to a conclusion.
    The Pedders GSR struts are just to firm for the front of the VS commodore to promote good daily driver handling on country roads (which I drive everyday).
    The front seems to feel like it just doesn't absorb any changes in road surface or contours.
    Anyone else with Pedders GSR struts on the front fine the same feeling from them on a VS commy ?
    Deek
    Aussie Aussie Aussie, Oi Oi Oi .
    VS 5.0L statesman
    Feb 2011
    Try some Pedders Gas Comfort they make an insert, shortend, worked ok in a vp i once had, if you want your car lowered your going to have a bumpy ride no matter what because most to all lowered spings have a firmer spring rate.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    darky82 is absolutely correct,my car is lowered and I cant feel any soft cushioning in the front,I just have to run over a small rock and I can feel it
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I got pedders in the front, but i think the weight of the 5ltr helps make them work
    Reaper
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Lol this thread made me think of my ol' VS.
    It had pedders shocks but the other way around. Comfort gas in the front and GSR in the back ( IRS ) and superpro Urethane bushes in the front with standard springs and sway bard all round.
    The back felt good, fairly stiff , the front was softer and i wished i had put the sports ryders all round but over rough roads it was still reasonably comfortable.
    I reckon you have gone too far towards sports with GSR's , lowered, and sway bars if its comfort you are after. Just depends.
    The GSR's will soften up in about 30 thousand k's ( less if your on rough roads ).
    Did you use rubber or poly bushes ?
    Oct 2004
    Jurien Bay WA
    Quote Originally Posted by greenacc View Post
    I used a mixture of both rubber & poly. I mean to say I don't mind a firm ride at all, as I have a VY V6 ute with King ProSport Coil overs / heavy rear king springs / ProSport shocks & heavy swaybar. It's low low & it shits all over the VS for ride control & feel. Although the VY is a heavier car.
    It (the VS) feel like the spring to shock rate on the front is not to well matched up. To much compression & rebound dampening maybe. The earlier posters comment about the V8 engined VS being ok make sense in some ways to me.
    The movement you get from most average to rough country road driving seems to give me a bump steering effect feel.
    I wondered whether others out there who had the same set up in the Pedders on a VS V6 felt the same ? I have had a comment from another VS V6 owner that they were going to try the Comfort or Touring gas struts on the front because heavy sway bar settings felt to stiff with the GSR's.
    Deek
    VS Executive S2
    Aug 2010
    melb
    Yep, I too have gas sports Ryder shocks up front with lowered pedders springs. Very stiff and bumpy ride. Everything rattles and squeaks when going over harsh road surfaces. I'm guessing there's nothing I can do about it.
    I have BOGE shortened shocks in the rear with kings superlows. The rear is a much softer ride.
    My VS is still definitely within the legal limit and really ain't that low. You'd have to look hard to notice it has an ever so slight drop in ride height. But it's a stocky, I try to keep her in good nick and I love it.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    My cars just got King springs lows, but combined with KYB Excel Gs in the front and Pedders comfort gas in the rear, even with SuperPro poly bushes pretty much everywhere it's still pretty comfy but handles pretty well too. Doesn't have the cool, Superlow look, but it's low, practical, comfy and handles well, so I'd recommend this set up but go KYB's all round, just ditch Pedders all together I think haha
  1. Pedders told me my shocks are about to shoot through my bonnet!?!??
    By javt99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2010, 11:17 AM
  2. Opinions on Pedders Sports Ryder
    By chargedvx6 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-10-2008, 10:26 AM
  3. NSW: VZ SS Ute - Pedders Extreme X shocks, coils and airbags
    By SSZ Ute in forum Parts And Other Items For Sale
    Last Post: 15-02-2008, 10:53 AM
  4. FS - VN VP pedders lowered REAR SHocks $50 VIC
    By timmy_tam in forum Parts And Other Items For Sale
    Last Post: 26-01-2008, 08:54 PM
  5. Pedders lowered springs/shocks
    By SlikUte in forum Parts And Other Items For Sale
    Last Post: 01-06-2005, 03:38 PM
