Results 1 to 20 of 20
Thread: gearbox not shifting
    vr commodore
    Feb 2011
    redbank plains
    Default gearbox not shifting
    hi all
    i have a vr and it wont shift into 2nd it just revs if you get up it up to 40kph then back off the gas a bit it will drop into 2nd then its fine PLEASE HELP
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like it is the Throttle Position Sensor...do a fault code check to confirm: Checking error codes VR/VS (Revised)
    If this fails, the auto cannot tell where the throttle is.
    vr commodore
    Feb 2011
    redbank plains
    EDGE3 its a auto
    hako when i done the fault code it was all 12's i sat there for awhile and it was still all 12's is there another way to test the throttle position sensor
    vz ss and vs statesman
    Mar 2009
    Sounds like the tps should put a code up but the only way to tell is by putting a new one in they are expensive try using a mates one first. Ebay ones arent very good either.
    vr commodore
    Feb 2011
    redbank plains
    Mar 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There is a test for them in the Gregorys manual with a multimeter - someone has one for a VG @ $10 on Ebay ...VG may fit if it has Ecotec...think it does. VN may also fit-----eyeball both or do a search on Google for TPS and see if they have same ID.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    emotec one turns backwards to vn so no good
    vr commodore
    Feb 2011
    redbank plains
    vr is not a echotech but i got a tps sensor from a vn and it looks the same so i will try tomorrow and let you all know thanks for the help
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    vr commodore
    Feb 2011
    redbank plains
    i thought it might be the 1st to 2nd shift solenoid but not sure thats why i thought would ask for help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by mackcrackie View Post
    If it was the solenoid it would have left a fault code.
    vr commodore
    Feb 2011
    redbank plains
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe check the VSS....also do a codes check again....disconnect, inspect and reconnect all cables to the transmission...when you put the new TPS in, did you check the drive adaptor was there - sometimes they get left out and the TPS will not work. (presuming the TPS is the same as VS)...will it manually start in 1 then manually shift up the gears OK?
  16. #16
    vr commodore
    Feb 2011
    redbank plains
    hi hako the adapter was there and put back in its only have trouble shifting from 1st to 2nd once it in 2nd its fine if i shift it manually it wont shift i still have to back off a bit then it shifts into 2nd then its fine
  17. #17
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
  18. #18
    Monaro CV8 02/ VS ute 98
    Feb 2011
    vr commodore
    Feb 2011
    redbank plains
    there is no kickdown cable because its electronic spoke to a transmission place they said its ether a bad solenoid or a faulty valve
  20. #20
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here is a link to a forum thread with your exact problem. 4L60E no shift 1-2 - Automotive Forums .com Car Chat
  1. Gears crunching when shifting cold T56 gearbox
    By Bargain Bucket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2011, 11:50 PM
  2. Clunk when shifting 2-3
    By omar302 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-10-2010, 01:15 PM
  3. Like shifting gears? Have a look here...
    By VT-565 in forum Parts And Other Items For Sale
    Last Post: 26-02-2009, 09:09 PM
  4. auto shifting
    By shumway in forum V6 Development And Modification
    Last Post: 31-01-2007, 06:05 PM
  5. auto shifting
    By bigbos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 07:59 PM
