Results 1 to 5 of 5
Thread: VR SS Fuel Pump Problem
    VR SS
    Feb 2011
    Default VR SS Fuel Pump Problem
    HELP I have just replace my fuel pump fuel lines and also the fuel regulator ! Car drives fine for a few days then i'll be driving along engine light comes on car cuts out and when i go to try start it there is a loud gargling noise coming from the fuel tank like it's sucking air and won't prime to the engine !!! after about 10 try's starts again and all good WHAT THE HELL !!! Even the guys at holden don't konw anyone had this promblem or can help me i don't think there are anymore parts to replce and im a single mum running out of cash .................... HELP ME PLEASE !!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check for error codes when the light comes on as described here Checking error codes VR/VS (Revised) being a 5.0 could be coil ,dizzy or ignition module its the most likely culprets for random stalling and not starting untill its cooled a bit
    VR SS
    Feb 2011
    Thanks for the error code info i know the dizzy has been replaced and the ignition module is new the last time holden put the car on the machine to check the codes for me they said it was the air sensors so they have been replaced to how hard can it be to find out the gargling noise and it's strange that it happens intermittently and some days it's fine !!
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    Mine (a VS 5.0lt) was making a gargeling noise in the fuel tank. the Fuel pump had failed. it was priming the car would try to start but wasn't able to keep up line pressure.
    when it did run my economy was Crap. my pump was less than 12 months old & there were no error codes.
    injectors were cleaned, fuel lines flushed, plenty of spark, new fuel filters after a bad batch of fuel.
    a high volume pump fixed my problem.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Could be a dodgy fuel pump,I have had 5 genuine holden water pumps fitted one after the other,so it wouldnt surprise me if the fuel pump is no good.But the good thing is that all the new parts you got put in should be under warranty so go back and get new ones
  1. Vr Fuel Pump Problem help
    By [QW-11-KE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:19 PM
  2. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  3. Fuel Pump Problem
    By W1LLO in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-08-2010, 10:17 AM
  4. Fuel Pump Problem (I think)??
    By Robbo VS3 in forum General
    Last Post: 13-02-2010, 10:46 AM
