Results 1 to 7 of 7
Thread: 1995 VS engine whine
    VS executive S1
    Feb 2011
    Default 1995 VS engine whine
    hi
    i have a 1995 vs series 1 3.8 with a T5 manual in it, the car makes a whining noise at all times when the car is moving, to me its coming from the gearbox/clutch area. because it makes the same noise no matter what gear im in and coz the clutches biting point is way out im thinking its the thrust bearing coz the clutch is old and worn, it doesnt slip or anything but yeah to me thats what im thinking. but before i go ahead and change the clutch when it still works i just wanna see if anyone else has had this issue?
    cheers
    Luc
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Does it do it in neutral when stationary......does it do it when stationary and clutch depressed.....does it do it rolling in neutral....does it do it in reverse.....does it change tone the faster the engine goes.?
    VS executive S1
    Feb 2011
    no whine in neutral, neither when the clutch is depressed it does do it rolling in neutral and the reverse gear itself whines and the whines tone gets higher with the engine revs.
    cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    Have you checked the gearbox oil level.Most T5's use dexron type auto transmission fluid instead of gear oil for their lubrication.I have a VS workshop manual and it states that the T5 uses 2.05 litres of dexron auto trans fluid with 150 mls of lubrizol 7906.But in the VP workshop manual I have, it says the T5 uses 2.05 litres of shell gear oil XGO 75/90,so make sure to check what type of oil has been used in it before topping it up, thats if it needs it of course.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could be the front uni dry (and ready to snap).....doesn't sound like the thrust bearing as it doesn't do it in neutral. If not uni, then as Brett suggests with oil or you have a bearing going in the box.
    Zarconia's Avatar
    Zarconia is offline Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    Yeah mines the same but i know for a fact my clutch is gone. Only does it under throttle and changing down gears
    VS executive S1
    Feb 2011
    Well on second thoughs I just listened to the sound and it does whine in neutral just not very loud. I'm also sure my clutch is on the way out. Here's hoping its the thrust and not gearbox problems
  1. Engine Whine
    By timmy975 in forum Car Audio
    Last Post: 23-03-2009, 03:31 PM
  2. engine whine
    By Timmos in forum Car Audio
    Last Post: 11-10-2008, 08:19 PM
  3. Engine Whine
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2008, 08:23 AM
  4. Engine whine
    By ghoul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2007, 12:50 AM
  5. VY SS Gen III Engine Whine?
    By VYSS346 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-01-2006, 10:05 PM
