Results 1 to 9 of 9
Thread: rotors
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    Cool rotors
    i going to buy some front rotors there is a person in n.z that is selling some,my front rotors on my car are 330mm rotors none slotted,the rotors i am looking at getting are off a vy they are 330mm hsv slotted rotors,my car is 94 vr hsv, would any body know if they would fit my car.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VR Series 2 EQUIPE
    Jul 2006
    Craigieburn, Victoria
    Speaking of rotors, what is the max size that can fit under the stock alloy rims on a VR II Equipe? I'm guessing 296mm? Can someone confirm?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Don't think they will fit properly. Looking at the DBA catalogue, VR/VS front rotors have a 70mm centre hole and the VY rotors have a 71.5mm centre hole.
    VR Series 2 EQUIPE
    Jul 2006
    I was looking at the DBA040B - which from memory I think are 296mm with the centre hole correct for a VR/VS? Can you confirm that in the catalogue? I can't find the specs for them online atm.
    I was just having a look through the gaps in the stock rims at the moment and wondering if 296mm + VT calipers with brackets would fit
    edit: Ah, I found this: http://www.dba.com.au/products/DBA040B
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Different offset, different centre hole.
    VR-VS are the same, VT-VZ are the same. VT-VZ will not fit the VR-VS unless spacer rings are used on the hub and an adapter bracket is used on the calipers.
    Visit my Facebook page
    VR Series 2 EQUIPE
    Jul 2006
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Interesting you say that... I talked to this guy today:
    VT VX VY VZ COMMODORE SS MONARO LHF TWIN PISTON CALIPER (eBay item 350440610143 end time 19-Mar-11 13:42:02 AEDST) : Cars, Bikes, Boats
    He says these calipers are straight boltons to a VR to suit VT rotors??!?
    I've found it so difficult to get straight answers on my research for this
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As far as I was aware, the calipers don't fit without the spacer. But never actually having bolted them up myself I couldn't give you a definite answer. Actually just did a bit of a search myself, no one on here that has done the conversion mentions anything about the caliper spacers, so I guess they bolt straight on.
    However, when going to the VE spec upgrade, caliper brackets are definitely needed.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Vt-vz calipers bolt on without spacers/adapters/special bolts. Straight fit with any vt-z rotor with hub spacers.
    Reaper
LinkBacks (?)
  1. 17-04-2011, 10:38 AM
  1. RDA disc rotors vs DBA rotors
    By Aus78Formula in forum General
    Last Post: 22-11-2011, 09:05 PM
  2. Which rotors???
    By paynetrainvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-02-2011, 01:04 PM
  3. New rotors VP V6 ABS?
    By thehsvmanv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2010, 05:39 PM
  4. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
  5. Replies: 20
    Last Post: 15-01-2008, 01:42 PM
