Results 1 to 5 of 5
Thread: VS Diff question
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Default VS Diff question
    Hi there all,
    Apart from putting all new bearings in it, what else should I get replaced??
    Thanks.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    It depends on how bad it is working,you might need to check the ring and pinion,axle,if the gearsets are worn they will need relapping.
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Cpt Awesome View Post
    get a bigger crown wheel. Like 3.45 or 3.9
    Its not a bigger crown wheel if you did you'd get one from say a Bw80 diff (vt s2 onwards) it wouldnt fit because its bigger.
    You actually need a different ratio crownwheel and matching pinion.
    As for OP question worth getting your LSD center rebuilt if its needed
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Update :
    Have just sourced a new LSD center for it, so thats going in it. So what else should I get done??
    Thanks.
  1. a diff question
    By POVRTY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 05:17 AM
  2. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  3. Diff Question
    By Nanos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 11:36 AM
  4. Diff question
    By joshsvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 10:50 PM
  5. Diff question
    By NVS 90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2007, 05:06 PM
