Results 1 to 7 of 7
Thread: VR Brake Booster
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Default VR Brake Booster
    Hi Guys.
    Before the Brakes were quite heavy to pull it up, but seems all VRs are like this, So anyway it still stopped no problem.
    I went to pop to the shops today and i have to pretty much put my foot to the floor to stop from about 20KM/H, and then its just a gentle stop. also when the car is off, i can keep pushing the brake pedal quite easy, some pressure builds up but im still able to push it to the floor, when i start the car with my foot on the brake firm, the pedal moves down. So Im not sure if its the Cylinder or the booster.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Sounds like the booster has failed check the hose from engine to booster see if its split
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If the pedal is spongy and has long travel with the engine off then its a faulty master cylinder.
    You said when the pedal is firm and you start the car, the pedal sinks down so this would indicate the booster is working correctly.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    well i just tried it in the VY, i cannot move the pedal at all when all the air is gone.
    In the VR, I Pump it a few times, it get firm but i can still almost push it all the way, but yes when the car is started the pedal moves down. So it might still be fine, well ill just get a used cylinder & booster and see cause i really dont feel like bleeding brakes i hate it
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    I would recommend a new master cylinder on your old booster. From what you describe, the booster is fine and the master crook.
    You WILL need to bleed the brakes, no choice.
    Flush the fluid while you are at it.
    DONT skimp, or do half arsed jobs on brakes. Your life and the lives of those around you depend on it.
    edit: agree with above.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    I Never do a half arsed job ever, what i mean was 2nd hand from my father inlaw that has a written off VR just to confirm what the issue is, but im thinking its the cylinder also. have to go get a bleed kit also, ffs and just bought a VY, cant move this one on till its sorted and yes the little brake power it has is scary
LinkBacks (?)
  1. 09-07-2011, 11:22 AM
  2. 11-03-2011, 07:47 PM
  1. Brake Booster
    By 33DISVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2010, 04:03 PM
  2. vs brake booster???
    By reaper01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2008, 06:20 PM
  3. Brake Booster
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2006, 09:24 PM
  4. Vp ss brake booster
    By jamo25 in forum General
    Last Post: 07-02-2006, 08:04 PM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
