Results 1 to 12 of 12
Thread: vs central locking
    96 vs ute
    Feb 2011
    hervey bay
    Default vs central locking
    hi everyone, my central locking dont work with key or without. is there anything i can liiok at to fix this problem? any help would b great. THANX
    MR_JORDZ's Avatar
    MR_JORDZ is offline Situation
    94 csi lexcen VR v6,
    Apr 2010
    $outhside logan,Queensland
    96 vs ute
    Feb 2011
    hervey bay
    thanx for the reply. yeah i checked the fuse and everythings fine. any other sugetions?
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Hey Mate.
    Jump In the Car, and push all the locks down, first try and see if you lift the driver side lock up, See if the other door unlock, if not, lock the door and try other passenger doors and lift the lock up, if they open and the driver side dont, i would say its the central locking motor in the driver side door. well thats what i would start with.
    96 vs ute
    Feb 2011
    hervey bay
    thanx guys tried all that and still no go. is there anywere i can download a owners guide to look at system
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There is no downloadable manual unfortunately. Has the central locking ever worked?...if it has, was any work done to the car just before it failed? If you PM me you email address I can email a scan of the wiring for the central locking as you will need to go over it with a multimeter.
    If you followed edals advice, the problem may lie in the BCM.
    VX SS
    Jun 2005
    Does it even have central locking installed? My base ute didnt have central locking.
    Ie are there two pins on the central locking fuse?
    holdendude's Avatar
    holdendude is offline ŞuρξЯŞ†★Ř
    *AL4SHO* VR Commodore
    Mar 2009
    Geraldton, WA
    Im pretty sure that the utility's came with a central locking key but didnt have the system installed, and i know a few mates who's dont unlock/lock using the central locking
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You blokes are right - utes don't have central locking.
    VX SS
    Jun 2005
    From series 2 or something they had central locking. Prior to that they just had a single button on the keyhead which would turn the interior light on and turn the immobiliser off.
    VS acclaim
    Mar 2011
    adelaide
    ive got a problem with my vs where when i press the unlock button on the key all doors but the drivers door unlocks, i can just pull it up to unlock the door and it also wont lock again. what would be the most likely cause of the problem? also the back rh had a simmilar problem but now works again...
  1. central locking
    By brooksy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2011, 09:41 AM
  2. vr/vs central locking fix
    By jharv58 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2011, 06:51 PM
  3. Central Locking
    By anarklov3r in forum Electrical Wiring / Questions
    Last Post: 14-03-2009, 09:00 PM
  4. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  5. central locking
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-03-2007, 06:32 PM
