Results 1 to 12 of 12
Thread: VR V8 Stato Stalling
    VR Statesman
    Feb 2011
    Wagga
    Default VR V8 Stato Stalling
    Hi Guys, You have all probably seen this before but......My 5.0 keeps stalling but starts a few minutes later, and is progressively getting worse. I have replaced the Ignition Module, and still no luck. It spits code 12 at me, I have spark when it stalls and cranks over without starting and still has spark, The fuel pump is new and I can hear it working when turning ignition on.
    Any Ideas??
    vs commodore
    Oct 2009
    Tamworth NSW
    Id be checking the hall effect sensor in the distributor,it can cause problems like your having,and sometimes it wont even log an error code to notify you that its got a problem ....
    VR Statesman
    Feb 2011
    Wagga
    Would the hall effect sensor throw code 46 if it was cactus?? as Im still getting spark
    vs commodore
    Oct 2009
    Tamworth NSW
    I havent got a list of the V8 error codes handy to look at, so Im not sure exactly what the error code 46 is on the V8's.But if error code 46 is something to do with the ignition system or ECU ,then yes,Id say it could cause that error code to set.The ECU might also use the pulse generated by the hall effect sensor to fire the injectors, so maybe thats why you still have spark but no go.
    VB SL/E
    Dec 2008
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You need to see if you have fuel pressure then. The pump might be shagged. Put a gauge on it and see. To me it sounds like your coil is shagged though. If you replace it, move it to a more convenient position.
    Reaper
    VR Statesman
    Feb 2011
    Wagga
    Ok, Coil replaced, enough spark to start a bush fire, sprayed some aerostart in when it trys to stall and revs pick up, so will have a look at fuel pump tomorrow, Although its is only 3 months old.
    replaced do far:
    Ignition unit
    Coil
    Fuel pump
    New injectors
    Distributer cap
    Plugs
    Leads
    VB SL/E
    Dec 2008
    Try testing the fuel pressure, both running and static, do you have a gauge to test the fuel pressure?
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Id say Crank Angle Sensor.. but V8's dont have them eh?
    Code 46 - No Reference Pulses While Cranking
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    check your battery leads/connections, specifically the earth.. my 5L vs did this a while ago. had spark, fuel pressure, no codes.
    wouldnt fire, then fired up but missed big time when it warmed up.. turned out to be a loose earth lead on the motor
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    Quote Originally Posted by GothicKidd View Post
    the hall effect trigger in the V8 distributer is their CAS!
    and yes it also fires the injectors.
    vs caprice
    Dec 2010
    brisbane
    thats right the hall efect sensor is also ur fuel injector timing
  1. VL stalling
    By shannon78 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-04-2010, 01:29 AM
  2. Stalling VP
    By 889bhp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2010, 02:40 AM
  3. VS almost stalling
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 01:07 PM
  4. stalling with a pod
    By commo69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 02:22 PM
  5. Stalling VN
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2006, 09:11 AM
