Results 1 to 4 of 4
Thread: Vs running badly
    HAZZA-VN's Avatar
    HAZZA-VN is offline License back 11/02/2011
    5litre Calais
    Apr 2008
    Default Vs running badly
    Howdy got a vs Series 2 97 model, with 157k on the clock, Just replaced plugs and leads cause it was running a bit rough, Its had all the cooling system replaced in the last 6 weeks...
    Was wondering what peoples thoughts are after about 10 minutes its idaling like my Calais in the shed with a 5 litre and no thermostat on it lol
    Speed never killed anyone. Suddenly becoming stationary, now that's what gets you...
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You don't say if it's a V6 but I'd presume so.....in that case and using the info that your cooling system has recently been replaced, I 'd say check for inlet manifold gasket leakage - this will cause similar problems - coolant heats up, expends and forces its way into inlet manifold and then into cylinders and causes a miss/rolling idle etc.
    HAZZA-VN's Avatar
    5litre Calais
    Apr 2008
    Cheers guys, I'm going to try getting the injectors cleaned, Mechanic at my work said with lower km on it, and if it sat around for awhile with fair bit in the fuel tank can form a bit or rust, then going through the injectors can cause problems there, so going to see about getting them cleaned, Also going to try injector cleaner when i fill the car up the next couple of times before i go of getting them cleaned, Cheers for the Help Ill let you know what the outcome is
  1. Car Behaving Badly
    By Dinwoodie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2010, 01:17 AM
  2. Why is my engine running badly?
    By astfgl in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-02-2010, 09:23 AM
  3. i need help badly
    By Magee in forum Car Audio
    Last Post: 17-04-2009, 07:42 AM
  4. VP Engine running badly
    By Tadeusz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2005, 10:22 PM
  5. Please do not think badly of me.....
    By dragrat in forum The Pub
    Last Post: 19-07-2004, 09:28 PM
