Results 1 to 6 of 6
Thread: Vs commodore issues
    VS
    Feb 2011
    PENRITH
    Default Vs commodore issues
    Hey guys need some opinions.
    my 95 vs commodore ran out of petrol the other week, died at the petrol station, then i filled it up and it was fine for the drive home ( 10 mins). i took it for a drive not long after and it cut out on me, and wouldnt start,,after getting it towed home and leaving it for 5 hours it then started. however when i took it for a drive around the block it cut out again.
    i was told to replace fuel filter and fuel pump which was done
    then the car seemed to go fine for a few days with no problems. Then after leaving it at work for 6 hours it would not start. at that moment i changed the EFI relay with the high beam relay. still nothing..the next morning i went back to work and fiddled with the injectors and it started but broke down twice on the way home and the engine light was showing, but started back up straight away. after leaving it for a few days the car seemed fine again but now it wont start. sometimes it does but cuts out right away .any help?? thankyou
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VS
    Feb 2011
    PENRITH
    I havent really checked the crank angle sensor but there was something on here saying like when it cuts out and tip 2 litres of water on it ,, then if it starts up it is the crank angle sensor, when i done that it didnt start but i still dont know how reliable that experiment would be.
    VS
    Feb 2011
    PENRITH
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    do that fault code test, see what you get. Also the was a thread on here somewhere regarding the terminal on the alternator, check that for tightness
    VS
    Feb 2011
    PENRITH
    , i done the fault code test and it told me 46 and 47,, something to do with the cas i believe,, hopefully when i get this changed everything will be fine. thanks
    M
    Priestly
  1. VT commodore starting issues
    By cds in forum Electrical Wiring / Questions
    Last Post: 09-11-2010, 05:57 AM
  2. Commodore VR Exhaust Issues :(
    By frostboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2010, 07:57 PM
  3. 94 VR Commodore having issues!
    By Bennymac86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 09:49 AM
  4. Mechanic Issues With VS Commodore
    By danielb3941 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2010, 07:10 PM
  5. VK Commodore issues PLEASE HELP! LOL
    By sugrnspice in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2005, 09:53 PM
Tags for this Thread
