Originally Posted by
D3V14NT
Hey mate,
I'm just about finished on a T700 rebuild myself (4l60e without the electronics really). Bought all the parts off a US ebay seller for peanuts, they're called CT Powertrain but there are a few on there. They also sell the repair manuals but I found everything I needed from Google.
If you're going to do it youself best thing to do is pull the trans out and strip it down to each individual component. After you've stripped it down clean it all perfectly. Then you can check it all out and see what will need to be replaced. Regardless of wear you should replace the band, all the clutches, all the steels and all the seals. Better to do it right the first time than to do it twice.
If you have enough spare cash there are also quite a few things you can do to upgrade the box. Some updated/upgraded parts include:
- Steel Pistons
- Beast Sunshell
- Wider Band
- 5 Gear Pinion
- Strengthened output shaft
- 13 vane pump kit
- Various kinds of shift kits
- Various other fixes (TCC apply fix is a common one for the 4l60e)
- Upgraded servos (corvette, billet, etc)
Check out the various sellers for an idea of what parts you can upgrade your box with.
Theres a few tools you'll need to do everything yourself or if you're handy you can make them yourself. Otherwise somethings you just won't be able to do. Some of the things I wasn't able to do included the fitting of the input shaft seals and the compression of the various piston spring retainers.
The 4 input shaft seals are solid teflon rings which need to be stretched out to be put into place, they then need to be compressed back to the correct size. They are a critical seal and will cause all sorts of dramas if they aren't sealing correctly.
The piston spring retainers are spring loaded plates which push against the apply pistons, pushing them back into place when the gear they apply for is no longer selected. I fitted stiffer springs with my shift kit and was unable to compress them down far enough to fit the circlip that holds them in place.
I just took those parts in to a trans shop and got them to do it. Cost bugger all and saved me the hassles.
I have a bit of literatur that I can send to you if you want. PM if you're interested.
Cheers,
Jarrad
if you fit a wider 2nd gear band make sure you fit a brandnew reverse input drum for it to run on or you burn the band out quickly
