Results 1 to 6 of 6
Thread: How can i adjust my fuel pressure
    VS 5.0L statesman
    Feb 2011
    Default How can i adjust my fuel pressure
    Hi, how can i adjust my fuel pressure on my vs 5.0L with an aftermarket performance type.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    What? Do you even know what you're asking?
    If you want higher fuel pressure get a higher pressure fuel pump like walbro or something.
    If you're not running a supercharger or turbo you're wasting your time. Higher fuel pressure is not going to make your car go faster because the amount injected by the injectors is still gonna be the same.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VL Commodore
    Dec 2008
    Isn't the pressure going to be the same no matter what fuel pump you use since the FPR regulates it at the rail?
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Quote Originally Posted by Z2TT View Post
    Lol yes.
    To get more pressure you need an adjustable fuel pressure regulator.
    VB SL/E
    Dec 2008
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    changing the fuel pressure without out adjusting the tune will make the engine run rich also, the injectors are designed to work with 43.5 psi (3bar) so why change the fuel pressure from that?
    the factory fuel pressure reg is vacuum referenced from the intake plenum at 1:1 ratio so if you were to boost the engine then the fuel pressure will also rise 1:1 as boost increases
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  3. low fuel pressure on vn v6
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2009, 11:54 PM
  4. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  5. fuel pressure
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 07:24 PM
