Results 1 to 2 of 2
Thread: no check engine light
    vs v6 commodore&vs v6 91 hilux 4x4
    Nov 2010
    brisbane
    Default no check engine light
    is there a particular bulb needed to go of the brown and white wire (F5) to use the check system im currently using a 12v smallest bulb from the vs headlights
    and the diagnosis connector wire white and black (B3) just gets earth to it yer
    its a ecotec v6 conversion trying to get fault codes from it ..?????
    vs commodore
    Oct 2009
    Tamworth NSW
    The check engine dashlight bulb is just a normal wedge type bulb,its the same as the other wedge type bulbs used on the other warning lights and for dash illumination. The wires going to this check engine dashlight are the following,a Brown/white wire that comes from ECU wiring connector terminal F5,(located in the blue ECU connector).The opposite side of the check engine dashlight circuit goes to a Pink/black wire that goes to fuse number 10 for power.
LinkBacks (?)
  1. engine check light came on then went off??
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2011, 11:02 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  4. Check engine light
    By Seeker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2005, 08:48 PM
  5. Check Engine Light
    By richie83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2004, 09:36 PM
