Hi, can any one tell me if the cam can be changed in the car, if so what are the procedures.. Cheers
a cam can be changed in any car as for procedures get a mechanic to fit it if your not real familiar with working on engine internals.
Yep
step1: remove old cam
step2: install new cam
When you do it, there will be a few things in the way, remove them as you. You will need the gear to dial it in aswell. Not particulary a hard job. Just an eye for detail is a good start. Do some reaserch on finding tdc.
Yeh i can dial the cam in, but what needs to come out to make room for the cam to slide in/out
If you can dial a cam in im sure ya can work out what needs to be taken out of the car to change the cam.
take ur bumper off ac radiator radiator water pump timing case rocker gear out manifold off lifters out if v8 dizzy and cam ready to come out
Hey it was a simple question man,
Cheers bro...
only thing to watch on changing cam is ur computer tune bud the bigger ur duration the differnt tune program u will end up needing for it to run proper and depending on the cam u go for is a depending on the compresion ratio of ur motor as well
If you need to ask then send it to the mechanic
