Results 1 to 4 of 4
Thread: Overheating Warning Light Keeps Coming On When Cold
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Default Overheating Warning Light Keeps Coming On When Cold
    The overheating warning light keeps coming on as well as the warning chime. This would be great if my car was actually overheating but it's fine. I leave the car overnight and start it in the morning and it comes on again. The guage reads it as being cold. It used to be only intermittant but now it seems to be doing it all the time. What could be the problem?
    Prior to this happening I had changed all the hoses, the thermostat, radiator cap, the water pump and the radiator itself in order to track down a overheating problem that I WAS having. That has now been fixed. I have cleaned the single cable that goes to near the thermostat housing as well as the dual cable that is on the right hand side. What else could it be?
    I have a level 3 dash cluster installed.
    I have checked the codes and none are being recorded.
    Any ideas?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try a new sensor I'd reckon. Not sure if there is a test but I'll look.
    Edit...there is a test in Gregorys involving suspending the sensor in water and heating it whilst noting the electrical resistance with a multimeter.....
    e.g. at 30C 2.268 k ohms
    at 100C .180 k ohms
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    The replacement sensor seems to have done the trick. Thanks Hako.
  1. SRS Warning Light coming on in the morning
    By holdenfish in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2011, 04:19 AM
  2. Overheated car, cold air coming from heater (HELP PLEASE)
    By simj79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2010, 07:37 PM
  3. Temp light keeps coming on soon as i start my vn (only on very cold nights)
    By 88VNCALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2010, 02:50 PM
  4. Engine warning light keeps coming on how come ?
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2008, 03:08 PM
  5. oil pressure warning light not coming on on startup
    By commodorewannabe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 10:56 PM
