hey there, my other half has her VS calais problem with that is the airbag cover on the passenger side has half lifted off.. is there any fixes for this or guides to remove and replace?
Ryan
The WaJin: 1991 s2 VN Commodore WagonThe Shtato: 1994 VR Statesman
ive got the same problem in my vs s pack. any help on how to fix would be great.
Ive heard you cant simply replace the cover as Holden don't make them anymore.
Apparently you'll have to source another second hand complete dash (with a decent cover).
This is what stopped me from buying a Calais a while ago....silly me. Im kicking myself now....
mine was peeling off heaps bad so i just got some tarzan grip glue and glued it back down.. looks like new again now
i was thinking to glue it down again, but would the airbag work as it should when the car is in a accident?...
MHHMMMMM!!!...
mhmmm
MhMmMmMmM
is it a defect????
i would imagine it isn't because they can't really deploy the airbag to check to see if it is, so if it's clean enough glue job then i'd say it would be fine, but im more worried about functionality
you can use glue but only around the edges, the airbag flips up, so if you use to much glue it wont deploy.
its also illegal to glue the airbag cover.
pretty sure its glued from factory anyway? i only used a little blob on each corner..
im not saying this is safe nor legal, if u wana paly it safe get it done properly
Guys please hear me: DO NOT GLUE YOUR AIR BAG COVERS. EVER.
I did it on my calais I had the same problem, I took the dash out and put a stato dash in - this is the only fix. Unless you can find an air bag cover in good condition which matches your dash colour and the chances of that are slim. If there is a safe way to glue the air bag cover you must TAKE IT OUT first and be CERTAIN that the glue has set before replacing it. By that point you'd be better off putting in another air bag cover or dash.
Can't stress this enough DONT GLUE IT DOWN. It's just not worth having it not deploy when you have your girlfriend or mate in the car and you being liable/responsible for their possible injury or death.
Happy to help anyone wanting to tackle it and get the dash out to replace it or install the stato dash. I just finished doing it in my calais and was well worth it. You should be able to do it in 6-8 hours in and out.
Not sure if the cops would get you on it, but I found there were a lot of differing opinions. Most places had no idea what they were on about and just said they wouldn't pass it (RWC), Holden dealers said it would affect how it deploys, other holden dealers said it wouldn't affect it. An air bag specialist said it was purely cosmetic and wouldn't affect it deploying.
That was good enough for me to leave it for a few months but I stupidly glued it down anyway, thank God it's out of the car now.
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
There you go.
I knew there was a reason i didn't buy this particular Calais. Couldn't be bothered with the hassle of replacing the dash as the airbag cover was the worst i'd ever seen.
