Results 1 to 5 of 5
Thread: 1st to 2nd Gear trouble at high revs
    VS Executive S2
    Oct 2010
    Central Victoria
    Default 1st to 2nd Gear trouble at high revs
    VS S2 3.8 Ecotec, Chipped and Stage 2 Shift kit, I recently had my Crank Angel sensor and Tensioner pully replaced, I picked the car up today and first things first, i ran it in. I soon noticed that the car would stop at 60kmh at high revs. It would just studer and rev ( Backfired one time also ). Can anyone think why my car will not shift from 1st to second at high revs? The problem has ONLY occured after the repair.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check they haven't disconnected the TPS. Why not take it back to repairers.
    VS Executive S2
    Oct 2010
    Central Victoria
    Quote Originally Posted by hako View Post
    I am planning to, Was just wondering because if i can fix it myself i ill. Because they have ####ed up twice now so it will be free and it will be the last time i use them ( First time they left the Rear stabalizer rubbers out.. I mean common even a first year apprentice knows better )
    TPS, New to cars and learning as fast as i can, But where could i find the "TPS"?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    TPS is throttle position sensor - it sits on the throttle body and tells the ECU (computer) whether the acellerator is at idle or mid range or to the floor so that it can then tell the transmission when to change.
    Also check this link: 4l60e Problems and Solutions - S-10 Forum
    Might be a good time to get yourself a workshop manual - Gregorys is the pick - will save many hassles.
    VS Executive S2
    Oct 2010
    Central Victoria
    i have a Manual.. i have.. Misplaced it lol
    THANKS for your help
LinkBacks (?)
  1. 2nd gear revs too high when engine is cold
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2010, 02:01 PM
  2. Revs too high
    By theperthvan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2009, 02:48 AM
  3. VS has trouble with revs
    By whitevanman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 10:45 PM
  4. revs too high!
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2006, 10:58 AM
  5. REVS. how high?
    By statesman_vs_s1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2005, 10:34 PM
