hi guys, my indicators stopped working the other day, i found tht if i press the hazzard switch on/off the indicators will work again. is my hazzard switch faulty?
i think there is a short in the hazard light switch, happening to a car my folks had, no idea how to fix it though.
Is the hazard switch plugged in properly? I think the indicators need it plugged in to work.
Sounds like it is faulty, make sure the connection at the back is plugged in properly..
If the hazard switch fails, the indicators won't work as they use the same circuit...this is a fairly common problem. Solution is a new switch.
