2 new O2 sensors to VS V6, I believe I have to reboot the computer to accept the new O2 sensors, correct or not? If so, best way to do so?
Replacing link pin sway bar bushes, easiest way to do so?
Thanks,
Dave
It helps (is quicker) but is not strictly necessary, as it will overwrite the current learned values anyway.
As ^ but don't bother with the rev. You can pull one of the fusible links from under the bonnet, in front of the fuse compartment instead of disconnecting the battery which avoids losing radio presets and/or re-entering the security code. I don't know off the top of my head which one but it will be marked "Eng Comp", "EFI" or similar.If so, best way to do so?
I wrote a "How To" on replacing the bushes which should get you started. It should be on the second or third page in the "How To" section.Replacing link pin sway bar bushes, easiest way to do so?
Thanks,
Dave
Cheapy I've had a look in the How To section, sorry mate, not seeing it.....
Cancel that, anti roll bar links..........
