Results 1 to 7 of 7
Thread: VS BCM Failure..
    Vs Equipe
    Aug 2010
    Ipswich
    Default VS BCM Failure..
    pretty sure my BCM has just crapped itself because my car will not unlock with the button, tried and tried but nothing, the light on the dash is also not flashing which i think is another indication..
    i can't get into the car at all because it seems at some stage the either the ignition or the door locks have been changed so i only have a key for the ignition..
    any tips on how i can A) get into this piece of crap and B) fix the problem thats causing this, otherwise it seems im stuffed..
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    so you can't open any doors or the boot? either get racq a locksmith or some wire down the door seal to pull the lock up, sounds like dead battery
    Vs Equipe
    Aug 2010
    Ipswich
    Quote Originally Posted by The1 View Post
    i can't open any doors or the boot because they're locked, they're locked because at some point either the ignition or locks have been changed, so i only have a key for the ignition, its something i didn't even think to check before buying the car, i don't think its a dead battery, its nearly brand new, pretty certain its caused by the BCM stuffing up..
    vr caprice 5.0
    Feb 2011
    qld
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Its easy to break things trying to force your way into the car. Like above, newer cars its much better to have a semi proffesional come break in for you.
    Reaper
    Vs Equipe
    Aug 2010
    Ipswich
    Quote Originally Posted by 5.0l View Post
    Is this your car champ or one you want to steal
    my car mate, i wouldn't go to the amount of effort i did for any commodore except my own, after spending ages trying to get into it with all kinds of tricks suggested to me, including disconnecting the battery to reset everything, which isn't a simple task from underneath the car, one of my mates started playing with the keys and it unlocked, i was so ####ed but at least i got back into it, just hoping it doesn't #### up again while i try to work out what caused the problem..
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Battery in keyhead or keyhead is almost dead. Get a spare keyhead asap before it dies completely. They can be had for around $90 from Mr.Minit.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  1. BCM failure
    By Calaber in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2012, 06:22 PM
  2. VZ key failure
    By Juan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2012, 03:22 PM
  3. L98 top end failure
    By redneck08 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-11-2010, 07:23 PM
  4. ESC Failure
    By VicCop in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-02-2010, 12:56 AM
  5. Failure
    By Ms Stato in forum Jokes/Humour
    Last Post: 12-11-2005, 09:09 AM
