Results 1 to 11 of 11
Thread: VR back end rattle
    Jahwah is offline Jamie91
    VR Executive
    Nov 2010
    Default VR back end rattle
    Hey guys just wondering if anyone can help me out.
    I have a annoying rattle coming from my back end was thinking maybe suspension but checked it out and suspension is all fine. Now leaning towards control arm or bushes? Any help would be very appreciated!
    vs commodore
    Oct 2009
    Tamworth NSW
    Stand the car up on chassis stands so the rear axle hangs free and get under there with a long screwdriver and lever the suspension arms back and forth etc where the bushes are to check for excessive movement.I know a guy who had a rattle coming from the back area of the car,he couldnt find it for ages.It turned out the jack in the boot wasnt tight enough in its holder and it was rattling,so check out how tight the jack is held in its holder in the boot.Its definitely one of those things that can be easily overlooked.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    You could check your boot, and take all the stuff in the boot out.. and see if theres a rattle. -Just look at it like the supercheap auto ad... Dont go do anything to extreme before checking where the noise is coming from xD
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Had a rattle in my rear. Found the centre exhaust rubber busted and the exhaust was just touching the corner of the petrol tank. The noise was only heard at low revs.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VR Executive
    Nov 2010
    I thought it may be the jack so I took it out. I pulled everything out oft car swell and the rattle is still there. Shocks and springs are being replaced tomorrow to make my car a fraction higher so I dint script on every speed bump and driveway lol
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Worn shockers can sound like a crate full of glass bottles.
    VR Executive
    Nov 2010
    I found the problem. Bushes on the sway bar and upper control arm bar rat ####. Replaced shocks and springs today rattle not as bad. Oldshocks were very bad. So next plan is new bushes and to figure why my car shudders and stalls
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    wait before u do that start the car up and get under the back. on my commodre the baffles inside the exhaust came loose and were rattleing around inside the exhaust
    and the back muffler was hitting the fuel tank
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VS 5 Litre BT1
    Jul 2006
    Broken exhaust hanger can also cause the exhaust pipe to knock / vibrate on the panhard rod. Mine did it (again) last week.
    VR Executive
    Nov 2010
    Checked out the exhaust and it defiantly wasnt that. The bushes on the sway bar are ####ed and sway bar is bent so I'm going to replace that and control arms and hopefully fix the problem
    1999 VS Ute
    May 2010
    Quote Originally Posted by RX25SE View Post
    Don't tell us this man I just replaced the shocks in my ute
  1. Back Seat in stationwagon wont go back up.
    By boostpig in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2010, 07:34 PM
  2. VX Rattle
    By vx6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2010, 10:30 PM
  3. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  4. back speakers rattle
    By New2Holden in forum Car Audio
    Last Post: 07-02-2006, 06:25 PM
Tags for this Thread
