Results 1 to 11 of 11
Thread: v6 t5 clutch shudder
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Default v6 t5 clutch shudder
    I know there are plenty of posts on the subject but I was wondering if anyone has actually fixed the shuddering drama that seems to be prone with t5s
    Its not confined to commodores....on the web ,the shuddering seems to plague many different cars with t5s.
    I am prepared to change anything in the setup if I can just get rid of this shuddering.
    On a hill from a standing start where you have to slip it it is damn near undriveable.
    When I first got the car it was perfect not a shudder...nothing under any load.After a year or so the clutch started to slip when accelerating so I had to change the clutch/throwout and of course had the flywheel machined .The spigot bush had spun in the crank so I got another and belted it in and it seemed tight so I put it all back together with new fork rubbers and it went well no shudders.... I always support the gearbox when attaching it to the bell housing.
    I used a clutch industries kit from repco like the old one was .I have never abused the clutch apart from the odd slip on a hill.After some time the clutch pedal action (only when the engine was running) stopped being smooth and it put a sort of vibration through the pedal and in came this shudder but I lived with it until I felt motivated to fix it. Engine mounts are also replaced.
    After a while I took it all apart again and replaced the clutch with a excedy one (standard pressure plate) and did the throwout bearing as well and machined the flywheel again (there was no noticeable high spots or discolouring).The spigot had spun again so this time I soaked it in oil for a couple of days and then loctited it into the crank and let it dry so the bond would be perfect.
    The old throwout bearing had been doing some pretty good grinding on the fingers of the pressure plate and the plastic inner bore of the throwout bearing that has a small spline on it had worn on one side completely away with some wear also on the bearing retainers surface that it runs against.I asked about it and I was told it wasnt too bad so I left the retainer like it was and smoothed out the wear so it wouldnt catch and lubed it sparingly and put everything back together.The bloke I bought it from told me the clutch industries clutch kits are not very good and that explained why I had this shudder It went good for a while...no shudder...no vibration... no noise ...perfect.
    After a while the shudder returned, vibration although not as bad has returned and the shudder seems much more severe when the engine is hot
    I have bought a new bearing retainer and steel throwout bearing retainer from mal wood for when it comes apart again.
    I have never considered the flywheel face but I am willing to try anything to fix the thing. I have read some of the newer friction surfaces can cause shuddering too.
    I was just wondering if anyone else shares these problems and has had any success fixing it?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    What sort of clutch plate do u have? Asu prob kno button clutches will always shudder cause there is little cushioning. Even a HD organic may shudder depending on what sort of cushion they put in the plate. The only t5 equipped car I have driven that was dead smooth had a brand new stock replacement clutch
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Nov 2003
    northside brisbane
    Quote Originally Posted by RUF 231 View Post
    Whatever is in the excedy kit for a standard setup
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    I have the same problem, gives me the ####s some days.
    My next thing is to replace the flywheel, clutch, and fork rubbers and clip, spigot bearing etc.
    But considering a Excedy replacement flywheel is $750, im in no hurry lol.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Way back when i first got the wagon ,i had the clutch replaced. I went for a daiken HD clutch. It shuddered terribly for atleast 8 weeks, but then went away. I was getting worried it wasnt going to go away. But now to date i have no shudder.
    Could it be though mark that the 3rd party friction materials have a better grip. Causeing a biteing effect on the flywheel as you let it go. Basically grabing the flywheel, causing the engine mount to compress and then the mount rebounding? Or could it be the clutch springs are doin the same thing(compressing and re-bounding), maybe they need reducing in size.
    The fix could be a heavier pressure plate, and a less grippy clutch plate.
    Reaper
    Nov 2003
    northside brisbane
    Noticed that the engine has a miss somewhere just off idle at the takeup point of the clutch and this seems to be transmitted down the driveline to the clutch...even at idle the engine puts out vibration that you can feel through the wheel and that seems to stay through the revs right to the critical takeup point. Ive considered asking a tune specialist if anything can be done to tune this out but havent got around to it.The car has extractors and a low restriction exhaust , a solid axle type lsd 308 diff and a kand n filter....id be interested if any of this could influence the tuning...I wouldnt think so but Im open to possibilities.
    VS V6 Executive
    Aug 2008
    Default Same kinda issue here too
    1996 VS V6, new engine mounts, new excedy HD, fly machined, pacemaker extractors (burning thru the clutch adjustment nut... cause its made of $%^$ plastic!) 1 year later:
    shudder sucks, heat makes it worse, drive like ur moma with no issue, watch automatic mazda 2's flog u off the line... drop the clutch with the gas and afta some smoke ur ahead! however, conventional peak hour in the city makes my clutch leg bigger then the other.
    A clear cut solution would b too much to ask for, so I'll just say, Thats why we love Holden It aint a commodore unless u can hear the lifters clack, the rods bend, the back right wheel spin as u fire it up.. with 1 liners down the street. its all good.
    But if there is a solution that aint, get a new 1, then i'm listening!
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    Just puttin it out there i got it too just started happening in the last week
    Stuntmanmike: At least he didn't advise for me to check the head light fluid and bring it in to tune the radio...
    VS V6 Executive
    Aug 2008
    So... if you have a t5... you have clutch issue. I wonder if Holden ever put a recall out for this...
    VX SS
    Jun 2005
    Mine has had the shudder since Ive had it and mine has more to do with the load and the amount of slip you give it when taking off.
    Light load (ie flat or downhill) the shudder is non existant.
    Up hill giving it a bit more it shudders but if you slip the clutch longer then its smooth.
    Ive just put up with it. Some cars (Landcruiser) are notorious for clutch shudder
    s1 vt
    Jul 2005
    had massive shudder issues from a standing start slowly and replaced everything above, still had it,then the clutch cable and got rid of it it was catching internally but only when under load. @ 60 from Holden was a good move. may not be the cause of some here but is something else to think about, also apparently the outside journal of the input shaft also wears down, this up to a few years ago was a serviceable part through Holden which is another reason for odd wear in the throw out bearing and shudder.
  1. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  2. [Ecotec] shudder once installed new clutch
    By psivyv6 in forum V6 Development And Modification
    Last Post: 04-10-2009, 01:27 AM
  3. bad clutch shudder
    By MattyVRss in forum V8 Development and Modification
    Last Post: 19-09-2009, 07:01 PM
  4. bad shudder
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:12 AM
  5. Overdrive Clutch Shudder
    By SeaComms in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-12-2006, 06:46 AM
