Results 1 to 13 of 13
Thread: Heater control rod not working
    VB SL/E
    Dec 2008
    Default Heater control rod not working
    I put a stereo in the VS the other day and I pulled the heater control out as far as I could without disconnecting it but now the rod does not move real good with when the knob is turned, it does move the rod but not much, have I broken something or ir is it fixable?
    VS 5 Litre BT1
    Jul 2006
    Did you undo the white clip that holds the rod in place ?...it is on the left side of the drivers footwell. Check if this is either broken or the rod has slipped backwards in it and maybe just need adjusting.
    Check this link for pics. It is what I used when I changed my HU.
    Complete VN,VP,VR,VS,VQ,VG Headunit Guide [56k warning]
    VB SL/E
    Dec 2008
    The rod is not moving in sinc with the knob, the clip is still in place on the rod.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    reconnect the rod to the clip...if the clip is broken you can buy new ones or use a very small cable tie to lock it in. Make sure that when you reconnect the rod that it does compress the black button bit when dialled to cold.
    1998 VS Ute
    Jul 2010
    Perth Hills
    did exactly the same thing putting a new sterro in my vs ute, never got round to fixing it to date.. interested to see how you fix it
    Making a 4 cylinder fast is like telling everyone your gay. At first you might suprise a few people but in the end, you're still a fag.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here are some pix of the clip and the arm....you should also see the black button that must be depressed by the white arm to turn the heater OFF. I haven't sorted these pix so just use as a rough guide.
    Edit...in 2 of the pix you will see a brass clip thingo that I added to hold the rod in the clip....rough but it works.
    Attached Thumbnails Attached Thumbnails Heater control rod not working-heaterbutton..jpg   Heater control rod not working-hotvacswon.jpg   Heater control rod not working-hotvacswoff.jpg   Heater control rod not working-heater-vacuum.jpg
    VB SL/E
    Dec 2008
    VB SL/E
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by VR38 View Post
    the knob does not move in sinc with the rod?
    When you turn the temp dial clockwise to COLD, the rod should pull the white arm back against the knob and depress it....if it's not depressing it, adjust where the rod sits on the clip so that it can depress the knob (which is quite hard to press in).
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    If the rod doesnt move with the knob it might not be attached, But if it is.. Do as Hako says, Just get a small screw driver between the rod and plastic should come apart ( I adjusted that way) but you could twisted the rod and should follow the thread.. but you gotta remove the rod from the Unit that controls heat and such..
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VB SL/E
    Dec 2008
    Let me try and explain this better, the rod and the white arm under the dash are 100% perfect,
    When I turn the temp knob on the dash the rod does not move with it, how do I re connect the rod with the dash knob?
    VSII Exec S/W
    Aug 2010
    I pulled off my selector dial thinking I needed to do this to access for stereo install - how stupid was I. Now the selector just spins freely as the spindle dropped inside and when I pulled mixer unit out slightly to reattach I couldn't get it right... I feel your pain.
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    on the back of the assembly where the rod connects, check to make sure you haven't broken the swivel tab or made the large cog move past it's full travel (i.e. teeth on both cog's no longer mating)
    I have a box of 50 of these i sell on ebay.
    Let me know if you've broken the mountings and i'll send you one for postage price only.
  1. Heater not working (climate control)
    By Cursed CX8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 05:42 PM
  2. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  3. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  4. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  5. trac control button and heater control lights!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 09:07 PM
