Results 1 to 5 of 5
Thread: Questions
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Default Questions
    Okay.
    Central locking; My Back doors unlock, but will not lock. - They attempt to lock but dont succeed.
    Amp; Where should I mount it in the back?
    Pwr/Econ button; Since installing amp ( I took my whole dash board and etc out, Drivers kickpanel and all the sideskirt things to hide wires), Ive noticed I dont have my PWR button, I thought it might been a blown bulb in the cluster, but Ive driven it with power button on and off and there is no difference, I knew the difference when it used to work. -ive checked my fuses, Ive checked the plug and connection it all looks good.
    Any help will be appreciated, thanks.
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VB SL/E
    Dec 2008
    vr berlina s2 and vp berlina s2
    Dec 2010
    pakenham
    had same problem with my lock the #### up after time due to no getting opened and closed all the time i tryed cleaning and lubeing it work for a while then started doing the same thing and after a while it wouldnt even unlock so i went out and got a new motor for the lock
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i know my passenger side doesnt always lock due to the red tab. as a test, remove the red tab then try unlocking and locking the doors, if they work fine, replace the tabs.
    amp: some ppl mount them upside down on the underside of parcel shelf, personally mount them on the back of the subbox if you have them, or make a U-shaped tray that bolts to the parcel shelf and mount the amps on that so they side the right way up.
    Power button: im guessing a loose connection, where im not too sure. did you happen to cut any wires?
    GothicKidd's Avatar
    Dec 2010
    South Australia
    I dont think It's a tab problem, I was sitting in my back seat watching them, and they shake a little, tho after unlocking and locking the central locking they all decided to work; What would that mean?
    Hm, so know problems with sub being so close to amp? Heard of not to put phones and stuff near a speaker because of the magnet :\ I might put in on my subbox then
    Only wires I did cutting on was from the wiring kit for my amp apart from that, no.
    Thanks for your inputs (:
    GothicKidd's Ride
  1. questions
    By makavel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2010, 05:40 PM
  2. Just a few questions.
    By Wombles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2009, 12:08 AM
  3. A few questions :)
    By holden_chik in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2008, 06:41 PM
  4. cam questions
    By Philthy in forum V6 Development And Modification
    Last Post: 03-02-2007, 11:44 AM
  5. a few questions
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2006, 02:04 AM
